RM European Auto Parts
Results 1 to 4 of 4
Thread: Transmission not shifting
    Dec 2018
    San deigo
    2002 525i
    The roads were flooded and I drove through a deep puddle and once I did the transmission stopped shifting. Any ideas what would cause this?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Welcome to the forum.
    I highly recommend that you get your car to a BMW specialist shop.
    This COULD be something as simple as a wet connector,.... if you're not ready to crawl under the car and dry the trans connector (s) with compressed air, you need to get the car to a BMW shop./
    Sorry, I do not know your skill level, or resources.
    Chris Powell
    BMWCCA 274412
    Dec 2018
    San deigo
    2002 525i
    Thank you for your input. I have been under the car and disconnected the plug but didn't use the compressed air. I'll try that next and then if that doesn't work off to the shop it goes. Thanks again
    Jun 2002
    E39M5, E500 4WD
    Does the speedometer work? Do you have a check engine light, trans failsafe, or other warning?
    Chris Powell
    BMWCCA 274412
  1. 1986 735i auto transmission not shifting into low gears
    By MeticulousGuy in forum 1978 - 1987 (E23)
    Last Post: 04-29-2010, 09:37 AM
  2. Transmission not shifting into 5th gear
    By ktmdrz400 in forum 1996 - 2003 (E39)
    Last Post: 06-19-2009, 06:21 PM
  3. Transmission not Shifting Properly
    By gumby77 in forum 1999 - 2006 (E46)
    Last Post: 05-12-2007, 11:33 PM
  4. Transmission Not Shifting Properly - Help!
    By scyrusurcys in forum 1988 - 1996 (E34)
    Last Post: 10-05-2005, 07:10 PM
