Results 1 to 5 of 5
Thread: Billet Oil Filtet Housing Mounts for V8
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    I know I’ve seen these before and I’m on my 3rd set of rubber ones since I’ve owned the car does anyone know where to get them? I’m talking about the little rubber mounts that always break on our oil filter housings. I saw an M5 that had some metal ones and I want them.
    San Jose, CA
    1997 BMW 540i 6 speed
    You're not r/r the cap correctly. You need to counteract the torque on the cap to prevent tearing the mounts. Use a 6x1.0x50 mm bolt threaded into the boss on the front of the canister to provide a handle. I've covered mine with a length of rubber hose.
    The cap need not be super tight: Once fully seated, the new O-ring seals the canister.
    I'd be willing to bet that the dealer has a "special tool" for this.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    That’s a bunch of work for nothin, rather just have better mounts. I always hold it with my hand to keep it from twisting but my guess is they just get old and dry out like everything else.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Those rubber mounts just get old over the years. Just unscrew and replace them. They are pretty cheap : About 2 Dollars at Napa auto parts stores (BMW oem
    Part # 11421436982).
    Jan 2015
    Tempe, AZ
    1995 525i/5
    I'd just replace them with stock rubber ones... there's no need to reinvent the wheel. I replaced mine two years ago and 45k miles later they're still fine, even after a whole bunch of oil changes.
    1995 525i 5-speed - Thread
  1. e39 M5 Oil Filter housing mounts
    By SD318ti in forum 1996 - 2003 (E39)
    Last Post: 01-05-2015, 12:20 PM
  2. DIY Oil Filter Housing Mounts ;)
    By Miss BimmerLV in forum 1995 - 2001 (E38)
    Last Post: 11-07-2012, 07:26 PM
  3. Oil filter housing mounts?
    By SpeedRac3r in forum 1995 - 2001 (E38)
    Last Post: 01-27-2011, 08:17 PM
  4. Ireland Engineering oil cooler adapter vs. VAC billet oil filter housing
    By project86 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-30-2009, 03:04 PM
  5. VAC Billet Oil Filter Housing
    By M triple in forum Race Cars & Track Parts
    Last Post: 10-11-2006, 08:14 AM
