Results 1 to 4 of 4
Thread: BMW E30 heater control valve not working
    Aug 2015
    Lafayette California
    1989 325i
    I have replaced my leaking heater control valve and heater core on my 1989 325i. I tested the valve before putting the panels on and it worked fine. Of course once I got it all together it is no longer working. Can anyone tell me what fuse controls the heater valve?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    here are all the fuses listed http://shark.armchair.mb.ca/~dave/BMW/e30/
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Remember the heater control valve is normally open. The valve closes when you turn the temp dial to cold. It's possible it's stuck closed, but unlikely. If your problem is no heat, make sure you have properly bled the coolant system.
    "Howdy, Folks!"
    Aug 2015
    1989 325i
    Thank you for the information
    Thank you. It was a new valve and even though I bled it once it did not work. After bleeding three times it kicked on. Thanks for your advice
  1. E30 Heater Control Valve Repair!
    By barbierij in forum 1983 - 1991 (E30)
    Last Post: 11-04-2020, 10:07 AM
  2. BMW HVAC Heater Control Valve 540i M5 64118374994
    By big mike 84 in forum Other Items
    Last Post: 09-15-2014, 02:51 PM
  3. BMW HVAC Heater Control Valve 540i M5 64118374994
    By big mike 84 in forum 1996 - 2003 (E39)
  4. Replies: 0
    Last Post: 09-15-2014, 10:13 AM
  5. NEED RECOMMENDATIONS FOR PART ASAP! bmw e36, HEATER CONTROL VALVE
    By Leviigee2012 in forum BMW Parts Wanted
    Last Post: 10-11-2012, 07:02 AM
