I have replaced my leaking heater control valve and heater core on my 1989 325i. I tested the valve before putting the panels on and it worked fine. Of course once I got it all together it is no longer working. Can anyone tell me what fuse controls the heater valve?
here are all the fuses listed http://shark.armchair.mb.ca/~dave/BMW/e30/
Remember the heater control valve is normally open. The valve closes when you turn the temp dial to cold. It's possible it's stuck closed, but unlikely. If your problem is no heat, make sure you have properly bled the coolant system.
"Howdy, Folks!"
Thank you for the information
Thank you. It was a new valve and even though I bled it once it did not work. After bleeding three times it kicked on. Thanks for your advice
