Results 1 to 10 of 10
Thread: Leaving the Interior Lights On..
    Jan 2018
    Earth
    I just gt back from dropping the E36 off at a friend's garage. Prior to getting out of the car, I had the interior lights on so that I could gather my stuff. I shut the door, locked it and put the key in the drop off box. Just then I realized that I forgot to turn off the interior lights. Question is, will the interior lights eventually go into sleep mode in order to keep the battery from wearing down?
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - if you left the interior lights in the 'ON' position, then the lights will continue to stay on.
    888.280.7799 | 6am - 5pm PST
    Aug 2009
    sunnyvale CA
    325is
    Was the door open? There are three positions. Off , lights on , lights on when door open. The last will turn off on a delay timer ~5 sec... or when the door is locked. The other mode however is when the battery is dead. ..... everyone is calculating 5 W x 3 = 15 W on a ~80 Amp hour battery or <64 hours unless you swapped to leds bulbs.
    Jan 2018
    Earth
    Non-LED lights and the switch was definitely left in the ON position. Doors were locked and the lights stayed on. Jumping it, if need be, isn't going to be an issue. I was just curious if there was a sleep mode after 16 minutes like the E39s have.
    germany
    6/96 318is
    Quote Originally Posted by Bostongruen View Post
    ...I was just curious if there was a sleep mode after 16 minutes like the E39s have.
    There is, but only if you left the switch in the center (auto) position. If you rocked it far left, the interior lighting will stay on until the battery is flat.
    The trunk light of a non-cabrio E36 will also stay on until the battery is flat. Been there, done that, added a timer.
    Jan 2018
    Earth
    This is one of those mistakes that'll only happen once. I'll be switching to LED interior lighting ASAP just in case.
    Jan 2018
    Earth
    13.5 hours in temperatures that dipped down to 5 °F and it started right up with no need for a charge.
    The Netherlands
    DE-spec E36 328i/M3 cab
    There is a ‘rest’ relay that kicks in after aprox 15 min to save the battery.
    I know this works when a door is open. I never testen it with the car locked and interior lights set to on.
    IG:
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Quote Originally Posted by MParallel View Post
    Doesn't over ride the switch on the dome light.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    The Netherlands
    Quote Originally Posted by somebody5788 View Post
    I might try it, just to rule out the EU wiring is different.
    IG:
  1. Update on my ghetto interior light proj..
    By Anfanger in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-13-2007, 04:54 AM
  2. Red Interior light project with pics.
    By Austin in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-08-2001, 09:28 PM
  3. NEED HELP: Wierdest problem, my interior lights
    By ///Arman in forum 1991 - 1999 (E36)
    Last Post: 07-10-2001, 10:52 PM
  4. NEED HELP: Wierdest problem, my interior lights
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 07-10-2001, 06:11 PM
  5. Can I change interior lights?
    By Silver Bullet in forum 1992 - 1999 M3 (E36)
    Last Post: 06-08-2001, 10:59 PM
