Results 1 to 3 of 3
Thread: Bosch error codes and remidies.
    Dec 2018
    San Diego
    2004 BMW 330ci
    I have a 2004 330ci (sports package if it matters), I have had this car for about 3 years now and I recently failed a smog test for a vacuum leak. I check the two tubes and yes replaced the cracked hose one. After that, I received a service engine soon light. I used a Bosch code reader at O'Reilly auto parts and the codes were:
    10179 - Thermal Oil Sensor. From what I know this is the oil sensor that is mounted with three bolts to the bottom of the oil pan?
    10371 - Mixture Preparation Bank 2. He ran the codes and nothing came up and he thinks they might be related to an o2 sensor
    10370 - Mixture Preparation Bank 1. Same as above. How likely is it that both go?
    10054 - Engine Misfire Cylinder 2. I am at 175,4-- so I am guessing either it's time for coils and or spark plugs?
    10139 - Thermostat Characteristic Field Cooling Mechanics? Honestly haven't looked yet.
    112 - Not defined code
    I know BMW parts like to work together I plan on using BMW and OEM parts.
    Any advice would be greatly appreciated
    Dec 2018
    San Diego
    2004 BMW 330ci
    bump
    Jul 2004
    Houston, TX
    36 Cylinders
    You most likely have more vacuum leaks. Very common.
    These would be best found by a smoke test.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. CE Error Code 51
    By BGM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-07-2013, 07:48 PM
  2. P1500 Error code(VSS intermittant)
    By Coop in forum Forced Induction
    Last Post: 01-21-2003, 06:37 PM
  3. Getting weird error codes when I have no problem???
    By AaronM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-16-2003, 12:03 AM
  4. Help! Error code E9
    By lagvoid in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2002, 10:23 PM
  5. Error code of 1-4-4-4
    By Dan in forum 1991 - 1999 (E36)
    Last Post: 09-06-2002, 12:42 AM
