Results 1 to 10 of 10
Thread: Please help diagnose ...
    Sep 2017
    Destin, FL
    1996 740IL
    Question Please help diagnose ...
    Greetings to the forum!
    Did not find specific answers searching around, please help me diagnose the trouble ..
    1996 E38 740iL
    Water pump and thermostat were replaced few thousand miles ago. Car had a defective fan that broke the old water pump. Car was running great after the replacement.
    First thing I noticed around 2-3 weeks ago was that the coolant was vanishing somewhere .. no visible leaks around the water pump, nothing under the car. Had to start adding around 1/2 pint in a week or so, sometimes bit more.
    Suddenly the exhaust started smelling like gasoline a LOT, MPG went down 3 units.
    Checked the codes, looked like Oxygen sensor @ Bank 2. I replaced the O2 sensor few days ago, MPG stayed low ... next thing, a PENDING code " P0116 Engine Coolant Temperature Circuit Range/Performance problem" came up.
    Today the PENDING on P0116 changed to FAULT.
    MPG is still too low. Smell of gasoline is less than it was before O2 sensor change but is still there ...
    EDIT: After the PENDING code turned to FAULT, the engine temp gauge started showing wrong. It was always at 1/2 when engine warmed up, now it stays at 1/4. I took out and plugged in again the connector from the sensor in the radiator and the gauge went close to the position it should be. Could it be that the radiatior sensor is causing low MPG ?
    I have a shi**y code reader and nothing better nearby at the moment, please share some ideas where to start looking for the problem ...
    Thank You ahead!
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    a bad thermostat causing a clod engine will reduce MPG
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
    Sep 2017
    Destin, FL
    1996 740IL
    Learning every day! Thanks for the reply! I assume the thermostat is OK, just replaced with OEM part. Messing with the radiator temperature sensor plug fixed the gauge for a short while ... could be that this is it ... new is on the way! Will post update after replacement!
    Dec 2018
    Edmonton, Alberta, Canada
    BMW E70 4.8
    Cooling system might have air pockets or sensor starting to fail. Try to compare temperature readings in the dashboard or scanner live data during engine warm up with with actual temperature. You can switch you dashboard to digital reading using service mode.
    Engine temp sensor is not in the radiator. It is in thermostat housing on M62 and behind intake manifold on M60.
    Sep 2017
    Destin, FL
    1996 740IL
    Hmmmm got it ... Water pump and thermostat were recently replaced, which does not mean that the new one couldnt have broken down ... is there a chance that there is a bubble in the system causing this ? Coolant is slowly vanishing from the system, maybe it sucked in some air and this is messing the thermostat up ?
    Just thinking out loud before buyng new sensor!
    Though as I have the fault code on the system, it probably cannot be just the air bubble in the system ?
    Dec 2018
    BMW E70 4.8
    Quote Originally Posted by vonpakkas View Post
    I don't think the new thermostat is faulty. If you have a code, most likely sensor has some problem, maybe intermittent. This is why you should check the temp values with scanner. For example, if the engine is cold and temperature outside is 20 degrees than coolant temperature should be roughly the same. If it shows 40 degrees, than you know the readings are incorrect. Or if during warm up temperature jumps from 20 to 60 in one second this is again impossible.
    Sep 2017
    Destin, FL
    1996 740IL
    I opened up the dashboard diagnostics and got some temperature readings from there ...
    First drive, with temp gauge showing engine fully warmed up, 15 minutes drive, KTMP reading did not go above 79C.
    Second drive, around half hour on highway, gauge stayd at 11 oclock never reaching the center, KTMP reading 69C max.
    Otherwise, the reading acted normally, temperature went up degree at the time etc.
    Any ideas ?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Your thermostat is not fully closing or installed incorrectly - that's about it for possibilities unless the temperature sensor is not reading the temperature correctly.....
    My BMW Repair YouTube Channel
    Sep 2017
    Destin, FL
    1996 740IL
    Hmmm, it was installed 3 months ago, the engine warmed up fast until just short while ago. New part on not, I have to agree that is has to be broken. Or could it be that the incorrect installment just did not affect it at first but started doing it in few months ? Seems unlikely as the installment is quite straight forward ...
    Ironic situation, bought a good OEM water pump and thermostat just for the reason that I would not have to replace it on this car again
    May 2013
    Rochester, NY
    2001 740i Sport
    I'd say it's more likely the thermostat is defective in that case. Wrong installation should have been obvious right away.
  1. Please help diagnose - whine when shifting gears
    By JaredG in forum 1992 - 1999 M3 (E36)
    Last Post: 10-15-2004, 10:05 AM
  2. vibration @ 60 mph, please help diagnose
    By nightkrawler in forum 1992 - 1999 M3 (E36)
    Last Post: 09-19-2004, 01:28 PM
  3. Weird Noise From Left Wheel: Please Help Diagnose
    By chubbyasian in forum 2001 - 2006 M3 (E46)
    Last Post: 11-23-2003, 05:06 AM
  4. Please help diagnose noise after installing
    By ronzo in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-22-2003, 09:45 PM
  5. Wierd noise from compressor +more, please help diagnose!!!
    By geha13 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-06-2002, 06:28 PM
