Results 1 to 16 of 16
Thread: Pulling Transmission - Any Other Items to Replace
    Aug 2003
    Dallas, TX
    Z3M, X5M
    Question Pulling Transmission - Any Other Items to Replace
    I'm replacing the clutch and flywheel and will pull the oil pan to address the oil pump nut. After a few years my shifter stopped sticking to the right so the shift-pins probably don't need to be replaced. Any other projects I should look into before track season picks up again?
    FYI:
    transmission and motor mounts are about 3 years old
    -Phil
    Springfield, Ohio, USA
    1998 Z3 Roadster
    When I did mine, I replaced the shift linkage wear items: https://www.bimmerforums.com/forum/s...-Shift-Linkage
    You will likely need to install a new shifter seal if yours is leaking and letting oil run down from the top of the transmission. You don't have to remove the old one; just install the new one pressing the old one farther in.
    I also replaced the shift pins, motor mounts, and transmission mounts, which you have already considered. I'm fairly certain I used E46 transmission mounts, which required enlarging the holes slightly.
    I installed new shaft seals on the input and output shafts of the transmission, plus the engine rear main seal. I can appreciate that most would not do that if they weren't leaking, but I had plenty of time over the winter.
    You should install an aftermarket stainless-steel braided clutch hose while you're there. I also replaced the master and slave clutch cylinders, since they had many, many cycles on them.
    You should consider replacing the clutch fork pivot, which is plastic and cheap. You can install an aftermarket stainless steel one, which I understand can squeak, but mine never has.
    Of course, you should replace the giubo. The nuts are one-time-use, so I would replace the nuts and bolts at the same time. Speaking of bolts, I replaced nearly all of the fasteners that I removed, but I live in a salty area and mine were corroded a bit.
    Aug 2003
    Dallas, TX
    Z3M, X5M
    Thanks, I'll add those seals to the list. There's a stainless steel clutch line installed and I already replaced the master and slave clutch cylinders.
    The projects will be spread out through the winter. Like most projects, I'm sure I'll find more issues as I pull things off. LOL
    -Phil
    Nov 2013
    Kelowna, British Columbia
    1998 BMW Z3 2.8
    Did I read this right?
    [QUOTE=Z-Thrizzle;30161699]”...... After a few years my shifter stopped sticking to the right so the shift-pins probably don't need to be replaced...”
    Say what? This auto-corrects? How long do I need to wait?
    May 2015
    Maryland
    1998 M Roadster
    There is a good deal on Blue trany mounts with cosmetic defects, stiffer then stock.
    http://store.uucmotorwerks.com/cosme...air-p1952.aspx
    Oct 2003
    Seattle
    99 M3
    Output shaft seal, shift shaft seal, rear main seal, Giubo, DS center bearing.
    I’d do the shift pins, plastic shift lever cup.
    Feb 2004
    san diego
    ...it depands
    Also, be sure to add the better material Clutch Fork Pivot Pin if not replaced already!
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by nevan View Post
    Ya, OE is plastic, aftermarket pin come in brass or aluminum depending on where (online) you purchase it from.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The nylon pivot is far superior from a longevity standpoint. The bellhousing is a very gritty environment. Metal on metal wears faster than metal on nylon.
    /.randy
    Western Washington
    chariot of the gods
    Randy,
    I’ve sheared nylon pins on cars with heavy pressure plates, if the clutch is upgraded I’d replace the pin regardless, especially on a car that sees track use.
    There is a stainless pin sold through BMW, off of a 6spd 8 series. It’s cheaper (~$20) than the aftermarket alternatives
    Aug 2003
    Dallas, TX
    Z3M, X5M
    [QUOTE=jdjkelowna;30162411]
    Quote Originally Posted by Z-Thrizzle View Post
    Yup it seems over time. it stopped sticking. This is probably after 4 years and a few transmission fluid changes. Not sure if you want to wait that long. It was probably the fluid changes that helped it.
    -Phil
    Dec 2007
    Great Dismal Swamp
    The shifter lean was caused by the LT-1 fluid swelling the teflon bushing linings. I suppose if you removed the fluid, the linings will eventually wear or contract back to the original clearances.
    /.randy
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Dirtsquirt View Post
    Randy,
    Got p/n?
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    I have a brass pin and it rattles at idle FWIW. I'd use a nylon pin again given the chance.
    oskaloosa,ia
    '01 3.0 ZCoupe
    I have taken several transmissions out with ranges of use from track only, to daily drives, I have yet to see an issue with the nylon pivot pin. Just sayin.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by rf900rkw View Post
    Thanks, Randy. That is really good to know, I was actually kicking myself for not going with brass one while I had the clutch reapced (back then, I didn't know that brass or aluminum ones existed). I guess I was lucky.
    - Zach
  1. Replacing Diff any other items?
    By Spacemonkey391 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-19-2013, 11:14 PM
  2. Pulling transmission - possible replace clutch
    By hcoles in forum 1999 - 2006 (E46)
    Last Post: 10-20-2008, 11:24 AM
  3. Replacing front suspension parts. Any other items?
    By fixture in forum 1991 - 1999 (E36)
    Last Post: 12-27-2007, 09:03 AM
  4. WTB: stock interior door pulls for any E36 coupe.
    By m3j0n in forum BMW Parts Wanted
    Last Post: 08-13-2003, 01:30 AM
  5. Any other parts to replace during AA Gen 3 install?
    By fpgm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-25-2003, 10:11 AM
