Results 1 to 6 of 6
Thread: e46 2003 M3 convertible top - steady red light no open
    Dec 2018
    st. louis, missouri, usa
    1978 bmw 320i, 2003 M3,
    I've checked the easy stuff, trunk boot is DOWN, and all associated fuses are good. Is the next step looking for a cracked wire?
    Whenever something has come up before the red light blinked, it is steady red now and does not move, makes NO noise.
    lil' help? I've tracked down a matching hard top, went to pick it up and because the top wouldn't move, I had to leave it behind.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think your best solution is to take the car to an indie shop that specializes in bimmers. Try www.bimrs.org. The shop must have all the proper software to diagnose the problem. Narrow your choices down via the better business bureau (www.bbb.org) website, yelp and the website of the local chapter of the BMW Car Club of America (BMWCCA).
    Mar 2016
    Portland, OR
    2002 325Ci Cabriolet
    Quote Originally Posted by commish View Post
    You really need to read the CVM Codes. Without doing so, you're just playing a guessing game. I use PA Soft and a Windows XP computer to read mine.
    Mar 2016
    Portland, OR
    Have you installed the Hard Top Mounting Hardware? Did your E46 come prepped for a Hard Top? Contrary to popular belief, you just can't install a Hard Top on your E46 unless it's been prepped for it. I included a picture of the Hard Top hardware.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Is the trunk shut?
    [QUOTE=commish;30
    lil' help? I've tracked down a matching hard top, went to pick it up and because the top wouldn't move, I had to leave it behind. [/QUOTE]
    Yes, you opened it to check the trunk boot down (the black thing with a lever on it inside the trunk) and closed the trunk but there could be a trunk switch not working.
    There have been cases when the wiring to the trunk fatigued and shorted or opened.
    Mar 2016
    Portland, OR
    Do your windows still drop a few inches when you try to put the top DOWN? If any ONE window does not go down, the top won't either. Try putting all your windows DOWN and then open the top.
  1. E46 FS: E46 M3 Convertible Top Assembly Complete Great Shape
    By Asmod3us in forum Exterior Lighting & Body Parts
    Last Post: 05-24-2017, 07:06 PM
  2. E46 FS: E46 M3 Convertible TOP LATCHES and Motor
    Last Post: 06-21-2015, 12:31 PM
  3. E46 WTB: E46 M3 Convertible top motor
    By MasterNater in forum BMW Parts Wanted
    Last Post: 02-27-2013, 09:46 PM
  4. Replies: 0
    Last Post: 10-28-2009, 05:35 PM
  5. 2003 BMW M3 Convertible, Gray w/ Red Leather, Every Option, CHEAP $29,900
    By NYC CLK in forum BMW Cars For Sale / Wanted
    Last Post: 06-18-2007, 04:27 PM
