Results 1 to 12 of 12
Thread: Wheel Bearing
    May 2018
    Red Deer, AB, Canada
    1995 BMW 320I Sedan
    Wheel Bearing
    I need to do my rear wheel bearing on my 1995 BMW 320i and I looked on CarID and they have a kit, which comes with a new hub too, but it says it fits a 318is 325i and 325is. Will it fit my car? I believe it will but I want to make sure before I buy it.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Check realoem.com for part numbers
    Oct 2003
    Seattle
    99 M3
    Wheel Bearing
    …use the last seven of your VIN to display the correct numbers in the diagrams within www.realoem.com
    Jun 2010
    NY
    1997 328i
    RiPete, don't buy from carid. I don't see the 320i listed on the popular bmw online stores but as long as you have the bmw part # from realoem you should be good. Check prices at RMeuropean.com PelicanParts.com Rockauto.com
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Here's some info. If those bearings have never been out then you're in for a tough job.
    The labor time for one bearing is 3.9 hours with tools and it's well worth the investment to have a shop with the correct tooling to do the job.
    Without the tools it's gonna take a while.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Oct 2013
    The Netherlands
    2011 E90 325xi
    An American with a 320i?!?
    May 2018
    1995 BMW 320I Sedan
    Quote Originally Posted by ultimatetester View Post
    Actually Canadian, and yes, the guy I bought it off of imported it from Germany.
    Wisconsin
    98 328IS 03 325xi
    Once you determine what parts to get consider buying, renting or borrowing a bearing kit like this. I used it to change mine and it worked like a charm, my bearing had been changed before though. https://www.harborfreight.com/front-...ers-63728.html
    Gave away my BMWs, driving a VW and an Audi now.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Quote Originally Posted by jmo69 View Post
    This'll work. The professional kits have an adapter attachment to pull the hub out, but smacking it from the inside with a BFH and large drift will knock it out with inner bearing race attached.
    Everything gets ruined in the process, which is probably why the bearing comes, or should come, with the hub. Even with the hub attachment some of them are stuck in so tight that the hub gets deformed anyway.
    See ya later,
    tony
    Wisconsin
    98 328IS 03 325xi
    I used a bearing separator to pull my hub but now I have a slide hammer that should work too.
    Wisconsin
    98 328IS 03 325xi
    ^^^^^^Neither one will damage the hub.^^^^^^
    Austin, TX
    E36M3, E60545i, F10550i
    Quote Originally Posted by tjm3 View Post
    Yes. I had to remove the entire driver's side control arm and take it to a shop to remove a stuck bearing. They were not able to remove it even with their tooling. Evidently, the previous owner welded the bearing into the control arm. J/K. So I had to buy a used control arm and install the new bearing in it.
  1. Worn wheel bearing?
    By Martin in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-23-2002, 11:02 AM
  2. Wheel bearings....
    By EuroKRN in forum 1992 - 1999 M3 (E36)
    Last Post: 10-02-2001, 01:43 PM
  3. How to spot a bad wheel bearing ?
    By fstbmwm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-02-2001, 05:39 AM
  4. wheel bearings
    By AlEkZ in forum 1991 - 1999 (E36)
    Last Post: 06-27-2001, 02:03 PM
  5. wheel bearing fails at 59,000 miles
    By sjhoney in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-11-2001, 01:45 PM
