Results 1 to 2 of 2
Thread: M3 Parts for my E36 328 Track Rat
    Jul 2006
    Raleigh, NC
    E36 Track Rat, E46 M3 DD
    So my off-season rear end rebuild project on my E36 328 track rat was complicated by the purchase of an E36 M3. Both are sedans, the M3 is an Auto. The M3 is rough but it was cheap, cheap, like too cheap not to purchase. The track rat is on a full GC M3 race coil-over set-up with Hotchkiss front sway, stock 328 rear.
    So the M3 is now on stands in my wife's parking spot in the garage (that's really popular this time of year), I need to strip off what's useful, and send the rest to a scrapper ASAP. It really sucks going back to working on your back. The track rat is on the lift with the rear already off.
    So far my plan is:
    - Swap all four spindles. Luckily my new front hubs / bearings are the same for M and non-M. The rear spindles will get new ball joints and bearings while they are out.
    - Keep the half-shafts. The M3 ones have less play than the ones in my track rat currently. I'll do the boots probably and fresh the CV grease.
    - Pull the brake calipers and holders. These will get new seals. I will re-use my existing SS hoses.
    - Swap the brake master, as I think it is required to get the M3 pedal pressure correct.
    - Pull the S52 and set it aside for now. Warm compression is good, 170-180, but it needs every gasket and seal replaced. It's a leaky beast. My plan is to just do the M3 spindle/brake and LSD work first, and run an HPDE or two with that, before messing with the engine swap. One change at a time.
    - I've already pulled the LSD, not marked but should be a 3.38 I believe. I've also got a known good 3.64 LSD, I'm probably going to swap the 3.64 in first to try it.
    - Pull the EWS, DME, and keep the key. Although I understand that the DME won't be too useful to me, as it's programmed for an Auto. I'll have to pick up a manual one, or buy one of the many tuner versions out there.
    - Pull the gauge pod.
    Questions:
    1. Anything else I'm missing that I should grab off the shell before it goes to the scrapper?
    2. Anything I should know about the master cylinder swap? Presumably I should bench bleed it after I remove it.
    3. I'm a bit confused by the control arms on my 328. The previous owner did a lot of work to it so I think it already has M3 control arms. I'd like to re-use them. The ones on the M3 are beat. Pics are attached. I can find none of the typical BMW part numbers.
    Thanks!
    Glenn
    Oct 2003
    Seattle
    99 M3
    What year M3? It is a Sedan, so 1997 or 1998?
    Difference between '95 and '96+ E36 M3 spindle?
    All E30 models (including the E30 M3, with later years using aluminum control arms), E36 non-M3 models and the 95 E36 M3 use the same control arm geometry. In other words, the arms are geometrically/functionally interchangeable. For example; the 95 M3 or the E30 control arms can be used on the non-M3 E36 models in order to eliminate the rubber isolated outer ball-joints that are used on these models. NOTE: The Meyle Heavy-Duty control arms for the non-‘M’ E36 models also eliminates the rubber isolated ball-joints. I also understand that the all E36 specific CAs got a slightly larger inner ball joint to handle the additional chassis weight.
    The 1996-99 E36 M3 control arms have different geometry than all of the other E30 and E36 models noted here, including the 1995M3. The outer ball-joint and spindle mount is 10mm forward of the positioning for the other 3-series models. Additionally the Spindle to Strut attach interface changed (boss for LWR attach for lower two bolts got thicker) resulting in the tire 'tilted' closer to strut body.
    This change combined with the Upper Guide Support revisions aft/outboard and Centered FLCA Bushing yields more camber at full steering lock, and the strut in static position sits more upright.
    Note that the offset control arm bushings that are used on the E30 M3 and the 1995 E36 M3 are used to increase the positive caster. The 1996-99 E36 M3 accomplishes this by changing the Control Arm/Spindle/Guide Support geometry (as noted above) and using centered control arm bushings.
    All p/n's pulled from realoem-dot-com
    1995 Strut
    LH STRUT 31312226987
    RH STRUT 31312226988
    REAR SHOCK 33522227794
    1996+ Strut
    LH STRUT 31312228007
    RH STRUT 31312228008
    REAR SHOCK 33522228415
    95 M3 Spring “Hat”
    UPR SPRING PLATE 31332227348
    SPRING PAD UPR 3MM 31331128523
    96+ M3 Spring “Hat”
    UPR SPRING PLATE 31332227903
    SPRING PAD UPR 3MM 31332227902
    Canadian cars SPRING PAD UPR 9MM 31332227901
    Bearing/Guide Support/LCA/LollyPop/LCAB p/ns -
    95 M3
    L/R GUIDE SUPPORT 31332228345
    LH WISHBONE 31122227249
    RH WISHBONE 31122227250
    LH WISHBONE BRACKET 31121139789
    RH WISHBONE BRACKET 31121139790
    RUBBER MOUNTING F WISHBONE 31129064875
    96+ M3
    LH GUIDE SUPPORT 31332227897
    RH GUIDE SUPPORT 31332227898
    LH WISHBONE 31122228461
    RH WISHBONE 31122228462
    RUBBER MOUNTING WISHBONE 31129069035
    Splindles
    95M3
    LH KING PIN 31212227357
    RH KING PIN 31212227358
    96+M3
    LH KING PIN 31212227907
    RH KING PIN 31212227908
    325
    Guide support 31336779613
    UPR SPRING PLATE 31331135580
    LH WISHBONE 31126758513
    RH WISHBONE 31126758514
    RUBBER MOUNTING F WISHBONE 31129059288
    328
    Rear Spring Pads
    SPRING PAD LOWER 33531135420
    UPR SPRING PAD 5MM 33531136385
    UPR SPRING PAD 7,5MM 33531136386
    UPR SPRING PAD 10MM 33531136387
    UPR SPRING PAD 15MM 33531094754
    UPR SPRING PAD 21,5MM 33531091599
    E30 M3 Control Arms
    LH ALUMINUM WISHBONE 31121130823
    RH ALUMINUM WISHBONE 31121130824
    LH Steel WISHBONE 31121127725
    RH Steel WISHBONE 31121127726
  1. Dash display - e36 328 Track Car
    By BruceT328 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 10-22-2018, 12:36 PM
  2. E36 WTB: E36 M3 track rat/TT/HPDE
    By ddavidv in forum 3 series & Z Series
    Last Post: 02-10-2018, 10:52 AM
  3. will e36 m3 parts fit a e36 325is?
    By miami325 in forum 1991 - 1999 (E36)
    Last Post: 06-11-2006, 11:45 AM
  4. FS:Tons of e36 M3 parts.....also 325 and 328
    By magillicuddy189 in forum BMW Parts For Sale
    Last Post: 05-26-2004, 04:16 PM
  5. Will M3 parts fit on a 328?
    By cbloysM3 in forum 1991 - 1999 (E36)
    Last Post: 02-15-2002, 03:32 AM
