Results 1 to 11 of 11
Thread: E46 330D 2005 need ecu pinout
    Dec 2018
    poland
    E46 M57n
    Hi, I must connect clutch switch after swap AT->MT. Please send me dde 7 pins-out diagram
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    All the info you need is available here.
    www.newtis.info
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Dec 2018
    poland
    E46 M57n
    I cant find my ecu here. Vin pk14016
    Jul 2004
    Houston, TX
    36 Cylinders
    You have DDE 5.06/5.07... it's there. Try harder.
    https://www.newtis.info/tisv2/a/en/e...o/power-train/
    M57 is listed
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2018
    poland
    E46 M57n
    I have dde 7
    Jul 2004
    Houston, TX
    36 Cylinders
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    That's the part number.. You have dde5
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    -Abel
    Dec 2018
    poland
    E46 M57n
    ok thx! pin 50 is signal clutch switch. Which pin is voltage supply +12v?
    Jul 2004
    Houston, TX
    36 Cylinders
    Voltage supply is usually from a fusebox, originally Fuse 9 https://www.newtis.info/tisv2/a/en/e...dde5-0/spobXLa
    -Abel
    Dec 2018
    poland
    E46 M57n
    I connect clutch pin 2 to dde pin 50, Clutch pin 1 to ground in break sensor (pin2), and clutch pin 3 to break pin 1 (12v).
    Still clutch sensor doesnt work
  1. Need ECU Pinouts
    By carthik in forum Forced Induction
    Last Post: 08-14-2011, 06:46 PM
  2. 2005 E46 330d Injector / ECU fault
    By MattyBoy3906 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-21-2011, 01:55 PM
  3. Need ecu pinouts for 81' 635csi Eu
    By negyvas in forum 1976 - 1989 (E24)
    Last Post: 09-22-2008, 03:40 AM
  4. Need ECU pinout Diagram for Emanage Ultimate
    By 328iJunkie in forum Forced Induction
    Last Post: 04-27-2006, 11:20 PM
  5. Need ECU pinout diagram. Please!!!
    By 328iJunkie in forum 1991 - 1999 (E36)
    Last Post: 04-17-2006, 10:46 AM
