Hi everyone,
I've been having a slight leak from my windshield washer fluid pump (smaller pump) for a while now. Finally decided to do something about it. I am about to replace my pump, but can't find the hose clamp part number, does anyone have this p/n?
Thanks in advance
anyone?
I beleive it’s a clic-r style clamp. 8-9.5mm diameter range. It’s the same clamp that is used for the rubber hose where it joins the plastic washer fluid hose that enters into the hood.
BMW P/N 16131379229. You will also need the special pliers to re-install the clamps. They are easy to remove with pliers but impossible to re-install without the tool.
1998 BMW E38 740il - Vermont Grün Metallic, 150k miles, all stock. 11/98 build.
2011 Range Rover Supercharged - Rimini Red, Jet/Jet Interior.
2018 Mercedes GLE 350 - Diamond White, Soccer Mom kid-hauler.
1970 Chevy Chevelle - Pro-touring, 496ci BBC, custom everything.
