RM European Auto Parts
Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: error 115
  1. #26
    Jul 2004
    Houston, TX
    36 Cylinders
    The 107deg C outlet temp is correct and normal.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  2. #27
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Sometimes I read, but don't manage to force myself to believe. Abel has pointed out, in the document shown from TIS, that the UNAIDED thermostat opening will be at ECT sensor readings of 107C or even slightly beyond. I am not accustomed to seeing these temps, I'm guessing because the DME typically heats the wax ball and opens the thermostat slightly earlier.
    Therefore: Thank you Abel....again! Eller, your thermostat circuit isn't working, but it IS quite likely that the rest of your cooling system is okay. Given that the thermostat has already been replaced with an OEM part, the DME is probably the culprit, if your wiring tests were correct.
    Chris Powell
    BMWCCA 274412
  3. #28
    Jul 2004
    Houston, TX
    36 Cylinders
    Typically ECT and engine temps are some 5 deg C lower than the outlet temp, so it's 'okay', but the dme will open that thermostat earlier, if it were working correctly. They aim for some 99 deg outlet temp in the tune.
    Reverse flow cooling really changed things.
    -Abel
  4. #29
    Dec 2018
    denmark
    bmw
    Quess i need a new thermostat then.
  5. #30
    Dec 2018
    denmark
    bmw
  6. #31
    Dec 2018
    denmark
    bmw
    i've already tried two thermostats, a cheap one, and a more expensive one with oem code.
    There is even more expensive thermostats out there wit, and i think i need to go for one of those expinsive ones.
  7. #32
    Dec 2018
    denmark
    bmw
    radiator outlet is not 107 its only ( 7C ). close to the tempreture outside.
    shouldnt the termostat open and alow flow without help from the heating element in the thermostat.
    107C engine tempretur.
    7C radiator outlet, Lower hose
    no circulation=thermostat closed.
    do you guys agree?
  8. #33
    Jun 2002
    E39M5, E500 4WD
    Abel was referring to engine outlet temp, not radiator outlet. The TIS document I linked to shows that if the thermostat is not assisted by the DME melting the wax ball, you'll get 107C before the thermostat opens.
    You have replaced the thermostat twice; therefore it is unlikely this is your problem. IF your wire testing was correct, then the wires are okay. Which would leave only a fried driver in the DME.
    Chris Powell
    BMWCCA 274412
  9. #34
    Dec 2018
    denmark
    bmw
    i think this guy had the same issue
    https://www.e46fanatics.com/forum/sh....php?t=1123811
  10. #35
    Dec 2018
    denmark
    bmw
    i think the solution is to find a donor car, then take the DME, EWS, Ignition with keys. and i should be running. right ?
  11. #36
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, or find someone that can clone your DME into a used second hand one. There are people that can do this. Plenty in europe too.
    Then you don't have to change keys and ews module.
    -Abel
  12. #37
    Dec 2018
    denmark
    bmw
    i think i will go with the DMe, ews, and key swap.
    Found a whole set on ebay for cheap money, its the same year and everything.
    have a look
    https://www.ebay.co.uk/itm/BMW-E46-3...-/273494854538
    i need a new key anyways, the remote is broken, the chip inside is very corroded, and my left front door lock is also broken(due to broken remote) the manual lock is only for emergencys, and i used it like a thousand times now.
    . so this will be just perfect in my case.
  13. #38
    Dec 2018
    denmark
    bmw
    A new Dme fixed the issue.
  14. #39
    Dec 2014
    asheville, nc
    01 325xi sedan
    Glad you got it fixed, and to learn my output temps are normal; I was wondering!
    H&R Sport Springs, Bilstein B8s, and poly bushings (Thanks Chris!); Valeo SMF & non-SA Clutch, CDV delete, and E60 Shifter w/ ZHP knob; Beisan System VANOS Seals...
    Mtech-II Front Bumper (PO got bumped in parking lot!); Eagle Eye LED Tail Lights... Lots of PM!!!
  1. error code 115
    By rocket64 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-27-2018, 10:12 PM
  2. INPA error code 115 Hot film air mass meter - MAF failure?
    By Spirit Force in forum 1996 - 2003 (E39)
    Last Post: 06-21-2015, 10:07 AM
  3. Error 115 in GT1, Activation cooling map.
    By mazak in forum Diagnostic Software
    Last Post: 02-22-2011, 04:45 PM
  4. Replies: 114
    Last Post: 03-05-2008, 01:53 PM
  5. ***LIGHTING forum WEEKLY special, SLIM lbf error ELIMINATOR HID kits ONLY $115***
    By habbie in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-22-2008, 11:43 PM
