Results 1 to 6 of 6
Thread: Random faults appear?
    Oulu, Finland
    See my sig
    So story starts from a overvoltage fault code, over 16v. I have changed new AGM battery (coded and registered) and also new voltage regulator (alternator looked like it was changed 2013). After all that I'm still getting the overvoltage fault code sometimes. I looked from the TIS, and as high as 15,5v is normal and should be limited to that (even 16v if the battery is cold enough, but it hasn't been that cold yet on Finland): https://www.newtis.info/tisv2/a/en/e...ontrol/YRovfk4
    And lately the car has been randomly telling me SZL fault, parking brake failure and transmission failure (when you just unlock the doors and open it). SZL needs car to be restarted to go away. Other faults just appear once and go away.
    I ordered used Power module to see if it helps. I hope the random fault's are because of the overvoltage. But any other thoughts?
    My car 07/2004 730d.
    These are the codes I pulled after.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
    Jan 2016
    Ca
    2001 525it
    The problem with over voltage eventually it's going to damage a module. There are two things to check charging voltage and ac leakage or feed back from the alternator if that is over 2.5 then it's to high, also the ever important intelligent battery sensor, (ibs), which is part of the Negative battery cable, it is the sensor that controls how the alternator charges. We had a car towed in that had the alternator replaced a few times, but the voltage was way to high, the ibs sensor was fried. We don't replace the voltage regulator, we replace the whole alternator and then check the charging voltage and ac leakage of the new alternator.
    Oulu, Finland
    See my sig
    Well, on E65 there is no IBS on negative cable. It's the power module that controls the charging system. Gotta wait for the new module to arrive, as I bought it from ebay. Replace it and go from there.
    EDIT: today it showed up again, I just unlocked the door and *bling* transmission failsafe was on the instrument cluster for few seconds and then it went away and car works normally. No fault codes on the transmission either.
    Oulu, Finland
    See my sig
    Probably found the cause for the overvoltage issue. Since I got engine preheater and batter charger together. Every time car was warming for next morning and the battery charged I got the transmission fault and overvoltage code. Now I took off the charger and no problems so far.
    But the power module should pick up the charger in an hour and know's how to deal with it so I will gonna change the module.
    Also this code popped up today... Might be wiring or SGM related.
    Oulu, Finland
    See my sig
    Power module changed. It has been -5c outside and I can now see 14,6v-15,1v. I think that the old module was bad after all.
    Oulu, Finland
    See my sig
    Well, yet another CAN related fault code had appeared. Though I haven't seen DSC light to light up... So the problem whent away pretty quickly I guess.
    But after searching on that code, I might have found the reason and cause for the CAN issues... At least hopefully. Gotta check these ASAP:
    https://www.youtube.com/watch?v=0OfU21jFPoA
    And
    https://www.bimmerfest.com/forums/sh...d.php?t=429031
  1. random electrical fault
    By davebrandon7 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-22-2014, 02:59 PM
  2. 2004 545i SMG random codes and transmission faults.
    By dc3193 in forum 2004-2010 (E60,E61)
    Last Post: 03-13-2014, 01:04 PM
  3. Replies: 7
    Last Post: 07-26-2013, 04:02 AM
  4. Replies: 11
    Last Post: 06-20-2012, 01:07 PM
  5. Random OBC faults.. where are the sensors?
    By AlexHochbmw in forum 1983 - 1991 (E30)
    Last Post: 01-17-2010, 01:02 PM
