Results 1 to 5 of 5
Thread: E21 swap help.
    Mar 2018
    Westminster, Maryland
    E21 1983 320i m10b18
    E21 swap help.
    Hello, I have a 1983 320is that I wanna swap. My preferred method would be pop an m42 that I would build and turbo it before I throw it in. But any other ideas or methods of swaps would be great. As long as all the big v8’s stay out of this. I want to keep it a 4 banger with a turbo setup. Thanks
    Oct 2015
    RI
    1983 320is S52/2003 VR6T
    sr20det
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    E30 318IS M42 Turbo - Stock Internals
    https://www.bimmerforums.com/forum/s...tock-Internals
    Randy
    Oct 2018
    Burbank, CA
    2014 911S
    Been quoted $20-30k for a F20C swap (Honda S2000 engine & Box)
    Mar 2016
    Bentonville, AR USA
    91 318is - 83 320is
    Personally I would just do the m42. It's been done before, drops in with minimal modifications, and is a good fit. Plus even on stock internals and headgasket you can run around 10 psi with good usable power.
    With that said, a nice k24 using Kmiata trans adapter to a Getrag would be a sweet setup. I think you are going to run into oil pan mods, custom intake stuff, header, engine management, etc. which end up being possibly both expensive and labor intense. I recommend watching Speed Academy videos on their 240sx Kswap to get a good idea of just how much will be required. I'm fairly sure the front subframe issues they ran into will be pretty similar to an e21. Kmiata is currently putting together a kit to fit the e30 chassis, so I think a lot of what they put together for it "may" work for the e21.
    An f20c would be sweet as well like mentioned above, but they are just so expensive of a donor.
    91 318is
    83 320is
  1. E21 m10 to m50 swap HELP!
    By Fpessoa in forum 1975 - 1983 (E21)
    Last Post: 05-30-2016, 11:58 AM
  2. M52 e21 swap help
    By dyorkey325is in forum Engine Conversions
    Last Post: 06-12-2012, 04:12 AM
  3. Engine Swap Help!!!
    By BzAlwayzLit in forum 1992 - 1999 M3 (E36)
    Last Post: 04-02-2003, 01:40 AM
  4. Engine swap help + SC
    By Mitch P. in forum Forced Induction
    Last Post: 01-08-2003, 05:40 PM
  5. Instrument cluster swap, HELP !
    By vic_comp in forum 1991 - 1999 (E36)
    Last Post: 12-27-2002, 03:06 AM
