Results 1 to 12 of 12
Thread: Car shakes after a long drive
    Dec 2016
    Plano, TX
    BMW 335i convertible
    Hello guys,
    So I have started noticing that whenever I come to a stop after driving for 30 mins or so, the car shakes which I can very well feel it. No rpm jump. It stays still around 600-650 rpm.
    Its 2011 335i 6spd. MHD stage 1+ with new plugs and coils. No code or unusual behavior while driving.
    Any clue ?
    Sent from my S9+ using Tapatalk
    Jun 2017
    Denver, CO
    '08 E90 335xi manual
    I would start by monitoring for misfires under the threshold to throw a code.
    May 2017
    Ontario, Canada
    335i E93 N54
    Quote Originally Posted by Iftekar View Post
    Hello guys,
    Any clue ?
    So, you come to a stop. Put it in neutral, release the clutch, put the hand brake on, release the brake pedal and shut off?
    At which point does it shake?
    Is it just a 1 second shake, or continues?
    Only after driving for 30 minutes?
    Details bro
    Dec 2016
    Plano, TX
    Quote Originally Posted by relative4 View Post
    No codes. It doesn't sound like a misfire - the car kind of shakes enough to be felt.
    Dec 2016
    Plano, TX
    Quote Originally Posted by Codes2 View Post
    Details bro
    I come to a stop. Put it in neutral. Clutch released. No handbrake. Car still idling.
    It's not 1 sec shake, it continues atleast 30 secs.
    Funny part is, it doesn't happen always.
    May 2017
    Ontario, Canada
    335i E93 N54
    You noted it does this after 30 minute drives.
    Will it also do this at each light in the city after the car is warmed up?
    Just trying to hone in on the most likely culprit. Timing recover, gummed up VANOS, poor injector, etc.
    Do you happen to have a JB4 installed? If so, log this and upload. It may shed some light (fuel pressure, etc).
    Dec 2016
    Plano, TX
    Just because you asked I remeber, Once the car is warmed up, I think I get that similar shaking at the stops.
    I have MHD stage 1+ with FMIC.
    I will try logging and upload once that happens next.
    Dec 2016
    Plano, TX
    Vanos was cleaned few months ago. Never had a code for vanos- that was just a preventive maintenance thing that i did.
    May 2017
    Ontario, Canada
    335i E93 N54
    I'm not as familiar with the MHD logs, but if something is too far out, I imagine we'll see it.
    Ensure logging starts prior to the issue as well, driving, slowing, stopping.
    Nov 2005
    Kilmarnock, VA
    E53, E90, Triumph GT6
    how is this done? I've got a similar issue with my car.
    Jun 2017
    Denver, CO
    Any scanner with live data can monitor misfires.
    Are you gonna eat that?
    Nov 2005
    Kilmarnock, VA
    Problem is I don't think the DME is sensing it. So it won't report it to a scanner. I've got INPA, ista and typical ELM type scanners. I've reset adaptations and watched the rough running data. I can watch the rpm do a little dance but the DME doesn't seem to register anything as wrong. But I could be missing something obvious. So I asked.
  1. E38 not shifting after a long drive?
    By giorgos740i in forum 1995 - 2001 (E38)
    Last Post: 07-01-2009, 04:24 PM
  2. front end shakes after extended highway driving
    By wagnerone in forum 1999 - 2006 (E46)
    Last Post: 02-19-2009, 03:42 PM
  3. car shakes after rocker arm job..
    By daveisconfused in forum 1983 - 1991 (E30)
    Last Post: 01-06-2009, 01:58 AM
  4. Car shaking after changing rims.
    By luisbe in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-29-2008, 12:36 PM
  5. car shaking after spirited driving
    By pennpen in forum 1983 - 1991 (E30)
    Last Post: 03-31-2008, 01:38 PM
