Results 1 to 12 of 12
Thread: chain tensioner preload
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    after installing a new O ring , i do not find how we adjust the preload screw.... do we measure something ? Torque on the screw ??
    thanks for info !
    Sunny Cali,
    6.5 second 69 Camaro
    Great info Here----> http://twrite.org/shogunnew/fixes/engine.html
    Hats off to:Mark in NBA, Shogun,
    rv8flyboy,
    rvbflyboy,
    George Fontes, Very useful write ups, Thanks!
    I put the Tensioner info in a PDF file below:
    Attached Files Attached Files
    Sep 2018
    Belgium
    many thanks 8eights , but i wonder why preload it the same way as before ? when that O ring is hardend and must be replaced , at that time there will be chain stretch also …. so the chain guide is further inwards due longer chain …. and loosing a bit the preset spring tension …. I tought to put the screw some more in than was before… ?
    I would screw it in about 5 mm more , that also puts the O ring in a "new " place in the cilinder …
    Also , without anything to "measure" , those descriptions assume as it is still the factory setting.... but for most cars this is not the fact anymore…. the setting one sees is probably done by some PO who also didn't knew "how to"….
    i can be wrong …
    Sunny Cali,
    ...for what it's worth, My tensioner is turned 3.2 times to get the tension correct for 7 years now and no issues, I do plan to redo the top and front of the engine out of boardim in may.
    Sep 2018
    Belgium
    i inform monday at my BMW dealer what they ( still) know about it.... i'm curious.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The E32 workshop manual tells you. A bit difficult to find, go to the link, then click engine, it starts with the 735 M30 engine, then click on the top forward till you reach the section M70, from page 11-14.7.2 , not possible to go directly to the M70 engine https://www.bmwtechinfo.com/repair/main/481en/index.htm
    and this procedure is only possible when the timing case is removed
    On page ...7.5 it says
    Adjusting chain tensioner
    tightening torque for plug 40 Nm
    Important: cylincdrical end of the spring must point towards the piston
    loosen adjusting screw until it no longer touches
    crank engine ones in direction of rotation
    measure distance A
    push tensioning spring against the spring force as far as stop and measure distance B
    Note: a tensioning rail with sprocket is installed since the middle of 1990
    Adjusting distance A - B
    1 = version without sprocket 6 +/- 0.5mm
    2 = version with sprocket 5 +/- 0.5mm
    set adjusting screw to appropriate distance and lock screw by tightening the nut
    Sep 2018
    Belgium
    thanks shogun ! for some strange reason i can open Repair Manual disc 1 ... (with the E31) , but not anything on disc 3 as your link is a part of.
    So , without removing the timing case , we are working in the "dark" …
    I'm i wright , the cylindrical end of the spring in the piston , the conical one in the plug screw ?
    Jan 2005
    Japan
    here is the main link, there go to the E32 manual https://www.bmwtechinfo.com/repair/main/ there to engine and the always click forward till you come to M70.
    there you see the drawings.
    I did replace the o-ring years ago and just set the screw basically to the same position it was before. And since then no problem. The o-ring dia is not very much
    Oro Valley, AZ - USA
    see my signature
    More info here on a parallel thread to this ine:
    https://www.bimmerforums.com/forum/s...g-Chain-Noises
    2006 R53 JCW (British Racing Green) - 1994 E31 840Ci 6spd (AVUS Blue)
    2021 F56 JCW (Rebel Green) - 2000 E38 740i Sport (Titanium Silver)
    2017 F26 X4 M40i (Carbon Black) - 2007 E91 328iT (Deep Green)
    2012 E82 135i M Sport (Marrakesh Brown) - 2015 E84 X1 (Cashmere Silver)
    2005 E53 X5 3.0i Sport (Kalahari Beige) - 2000 E36/7 M Roadster (Oxford Green)
    2000 E38 740i Sport (Oxford Green) - 1999 E36 M3 Coupe (Fern Green)
    1995 E31 840Ci Canadian (Oxford Green) - 2000 E36/8 M Coupe (Oxford Green)
    2004 E46 330Ci (Oxford Green) - 2001 E36/8 Z3 3.0i Coupe (Oxford Green)
    2002 E39 525i Sport (Oxford Green) - 2002 E36/7 M Roadster (Oxford Green)
    2001 E53 X5 3.0i Sport (Oxford Green) - 2007 E63 M6 (Silver Grey)
    1995 E31 840Ci (Oxford Green) - 2006 E86 M Coupe (Sepang Bronze)
    2001 E39 530i Sport (Aspen Silver) - 2009 E92 M3 (Space Grey)
    2001 E38 740i Sport (Sahara Beige) - 2008 E92 M3 (Melbourne Red)
    2000 E38 740i Sport Canadian (Sahara Beige) - 1997 E31 850Ci (Jet Black)
    Sep 2018
    Belgium
    Thanks Chamberlin , i had seen it already .
    Shogun, i had tried the main link and so on... but nothing works here on my computer once at the E32 page .... page E31 works fine !
    Jan 2005
    Japan
    the site and the E32 workshop manual works for me without problem, I use internet explorer11 for that. Before I had some probs with google chrome for that site.
    Sep 2018
    Belgium
    thanks shogun, i will try thad ... have set my tensioner at 4 mm more screwed in than it was... as i had some chain stretch ( 6° and 9° retard cams ) , i don't think a bit more tension can't harm anything. Better than to less …. i hope...
  1. Do I have to use dummy chain tensioner to preload primary chain?
    By m3BMW95 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2005, 05:07 PM
  2. need primary timing chain tensioner part no!
    By rpM in forum 1992 - 1999 M3 (E36)
    Last Post: 01-29-2002, 03:21 PM
  3. vanos, chain tensioner problems?
    By rpM in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-16-2001, 09:59 PM
  4. vanos, chain tensioner problems?
  5. How difficult to replace VANOS chain tensioners?
    By UNVMYM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-30-2001, 11:22 AM
