Results 1 to 4 of 4
Thread: Pertronix II Module and Pertronix II Coil
    Tacoma, WA USA
    '78 320is 83 320i R.I.P.
    Anyone running this setup? What gap did you set your plugs to if you're using the regular small plugs like NGK??
    Oh SNAP!!! German Engineering is IN DA HAUS YAH!!!
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    Quote Originally Posted by Bimmerknut View Post
    We're running a pertronix II on our build with mechanical tii style distributor (no vac). The II version with the adaptive dwell can be run with coils that have a primary down to 0.45 ohms if you chose to. The standard pertronix I has to use at least 3.0 ohm primary coil or could burn out.
    We run coil part number 60104. Also using Denso iridiums at their gap out of the box; in our case two steps colder heat range IW27 at .028" . Motor is 13:1 compression so thats why chose this setup. Issues with hot ignition coils is the rotor button will burn up in short order. I just swapped to a racing solid strap rotor button (no resistor). Caps you should be using the brass contacts only. The aluminum cheapo ones will not last. An old tip for some improvement is if using a standard rotor button use the one from a 77-79 320i. The nose is narrower for less spark scatter. The racing one is even narrower than that. Wires we've a set of magnecors.
    https://www.bimmerforums.com/forum/s...4#post29999384
    Even on any street car I'd recommend the pertronix II and just about any coil they have to run with it. Convinced my bro which now runs one on his VW bus(standard coil for street use).
    If near stock motor I'd just run any standard plug brand you like. Back in the day I used to push autolite AR52 race plugs gapped at .050 with bosch red coil etc, it worked well enough.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    "If it flys, floats, or f*cks, rent it!"
    Tacoma, WA USA
    Hey AutoX! Nice to see you man! My car IS a "78 and I've only ever used Bosch cap and rotor with brass contacts. I also use Pertronix's Flame-Thrower II coil with 45,000 volts and .6 ohms. I want to be SURE but I think NGK's should be set somewhere near .035. That's what I need to confirm.
    Aug 2001
    NC
    Hey man np. With a flamethrower II coil and brass contacts; decent set of wires could open gaps to your liking honestly. Assuming you want the most out of what you got. Over .050 can have electrode contact on a 1.8L anyways(some piston dome). If not limited on time can trim stock electrodes (ngk's are nice) nipping the tip on them to cut back like 1/16" and re gap to about .040". Should be able to hold the plug and see the center with the strap just adjacent to it like this
    another method is cutting further and can also do a "side gap/side fire" but I don't always recommend it; it can mess with the "protrusion" or start point of where the spark first occurs (depth placement of plug in cylinder)
    like this
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  1. Need Help Finding the Model# for Pertronix II Module & Coil
    By Bimmerknut in forum 1975 - 1983 (E21)
    Last Post: 07-10-2018, 09:38 PM
  2. Where is the ews II module
    By Selleck95 in forum 1988 - 1996 (E34)
    Last Post: 09-15-2014, 10:13 AM
  3. White label EWS-II EWS II module 61 35 8 369 179 601 0820 003 E36 E38
    By mgoods50 in forum Car Audio & Electronics
    Last Post: 06-12-2013, 02:53 AM
  4. EWS-II guru’s! Is using a different EWS-II module possible?
    By BRAAP in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-08-2012, 04:27 AM
  5. WTT: Contour II's for Doublespoke II's
    By LarryL in forum Wheels and Tires
    Last Post: 05-02-2005, 02:52 PM
