RM European Auto Parts
Results 1 to 7 of 7
Thread: TPM has a malfunction message and heat and heat lighting suddenly stops and starts
    Dec 2018
    Buffalo, NY
    BMW X3
    I have a 2014 BMW X3. It has 54,000 Miles on it. I'm have been getting a TPM malfunction message for about a week now. "System unable to detect tire pressure manually continue driving is possible, consult service center". I have checked the tire pressure. Pressure is good and I can't reset it. In addition, the heat was running this morning at about 70 degrees. Suddenly it turned off along with all the indicator lights(other lighting works fine). After about a min. everything came back on.
    Any suggestions on what could be the issue.
    Eli
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    These are multiple issues, not just one. With a 2014 vehicle, your best bet is to take the car to a BMW specialist shop, or the dealership. The car needs to be connected to ISTA or another BMW specific diagnostic tool to ask the IHKA (a/c) and TPMS systems why they're unhappy.
    With modern cars, there's little chance of diagnosing these things without the proper diagnostic computers to run the appropriate test plans.
    Chris Powell
    BMWCCA 274412
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Go to www.bimrs.org to find a reputable indie shop that specializes in bimmers. How old is the battery? Whacky voltages cause whacky issues.
    Dec 2018
    Buffalo, NY
    BMW X3
    The battery might be the original one. I might try to replace it.
    Thanks for the tips.
    Jul 2004
    Houston, TX
    36 Cylinders
    Keep in mind you can't simply replace battery plug and play. It needs to be programmed in, or else you will make the situation potentially worse.
    Background: the car keeps track of how the battery is aging, and it changes charging methods as the battery ages. This is to be able to prolong the battery life.
    When you replace a battery, the car needs to be told a fresh battery has been installed, and the battery's capacity. Unfortunately, this is not as DIY as it used to be.
    I think your TPM sensors' batteries are dying (yes they have a battery in each one.... the joys of 'convenience'). This usually requires the TPM sensors to be replaced.
    A proper diagnostic will tell you what and which.
    The climate control issue is likely a completely separate issue.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Dec 2018
    Buffalo, NY
    BMW X3
    What would a sensor or battery for sensor cost? I made appt with the BMW dealer.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    The battery in the sensor is integrated, so you cannot replace it. The sensor can cost anywhere between 40 dollars for a generic, and about 125 for OEM.
    They have specific tools at the dealership or a well stocked independent to see if the sensor is transmitting. Typically these sensor are suppose to last about 10 years, so at about 4 years I would be surprised if you do have a bad one.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. Transmission malfunction message
    By datus in forum 2004-2010 (E60,E61)
    Last Post: 11-02-2016, 01:49 AM
  2. 2011 X3 DriveTrain Malfunction message
    By abhi234u in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 02-12-2016, 07:49 PM
  3. 09 335i Electrical system malfunction! messaged on iDrive HELP!!
    By hautedr1ver35x in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-10-2015, 09:49 PM
  4. 04' 545i battery malfunction message
    By juanes3824 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-20-2013, 08:18 AM
  5. DSC malfunction message
    By Dse7ven in forum Engine Conversions
    Last Post: 10-24-2011, 09:49 PM
