Results 1 to 8 of 8
Thread: E34 520i aircon dramas is gassed yet no cold air
    Nov 2018
    Straya WA
    1994 E34 520 1996 E36320
    Rather new here so bear with me,i had a new compressor fitted about a year ago along with the dryer and valve-then went overseas for a month came back and no cold air,i have taken it back to the company that fitted the new part i supplied though they said it leaked from the top of the compressor,i went and got another opinion to be told they leak from the front not the top though the old bloke said it could be the condenser...A year later i have taken the front nose off the car as i have a spare from a 535i I use as a parts car and was going to fit cracked the fillister head on the condenser pipe to find plenty of gas is present and has not leaked,the fan was tested while out and no problems,all fuses in regards to the A/C are fine,microfilter has not been replaced anything electrical i need to know as mechanically the A/C seems sound, any help would be appreciated.
    moroza's Avatar
    BFE
    E34T
    Two different shops gave three different ideas as to where there's a leak? Sounds like nobody actually checked with dye or a sniffer.
    Is the compressor turning on? Do you have pressure numbers for the cold and hot side?
    Nov 2018
    Straya WA
    i did not get any numbers from anyone Moroza,just a lot of talk though i still have gas in the lines as it was the green dye i saw when i briefly cracked the nut and closed it so i doubt i have a leak,compressor as far as i know is working being a new part though come Monday i may have to get a auto sparky to check it
    moroza's Avatar
    BFE
    E34T
    Compressor may be perfectly healthy but the electrical systems turning it on - pressure switches among other things - may be malfunctioning. Look at the compressor pulley while the engine's running. If the outside (driven by a belt from the main crankshaft pulley) is turning but the center isn't, the compressor is not running. If the center part is spinning - often with an audible click as it engages, and a palpable load on the engine - but air is still not cold, we've got deeper problems.
    Green dye is good, means whoever last charged it has at least a basic idea of what they're doing. Do you see that green dye anywhere other than where you cracked a line?
    Nov 2018
    Straya WA
    No ! i did have another tech look at it though all he did was use a uv light to tell me if it was leaking,he saw some old dye on the condensor and told me to look at that though i think your right it is pointing more to a electrical issue,thanks for the heads up !
    Nov 2018
    Straya WA
    Would like to know where the a/c relay is located on a e34 1994 520i the frost switch is on yet the clutch is not engaging all fuses are good has one wire to compressor and a earth which is sound i have looked through the posts here and online so far cant find where it is located
    moroza's Avatar
    BFE
    E34T
    Got wiring diagrams? They give component locations as well, though these are specific to the US market and may be different from yours.
    Nov 2018
    Straya WA
    Going to bite the bullet mate and take it into the auto sparky thanks though for your comments Moroza
  1. Ultimate cofused conversion - E34 520i flywheel !
    By Cressidom in forum 1988 - 1996 (E34)
    Last Post: 09-16-2006, 05:27 PM
  2. Euro E34/ 520i for sale
    By BimmerFreak in forum 1988 - 1996 (E34)
    Last Post: 10-07-2005, 07:10 AM
  3. !!!!!! ***** E34 520i Drops Below 1 RPM & Stalls ***** !!!!!!!
    By bmwreloaded in forum 1988 - 1996 (E34)
    Last Post: 05-24-2005, 04:21 PM
  4. How to increase power on an E34 520i 24v?
    By Mas20012 in forum 1988 - 1996 (E34)
    Last Post: 05-21-2004, 11:40 AM
  5. E34 520i, how to make it better?
    By normality78 in forum 1988 - 1996 (E34)
    Last Post: 03-18-2003, 11:06 PM
