Results 1 to 2 of 2
Thread: INPA not working
    Dec 2018
    Trumbull, CT
    2004 x5 3.0
    INPA not working
    2004 x5 e53 I repaired brake lines and need to bleed my abs brake system. I bought a cable off ebay and downloaded mikes easy software. When I down loaded it I got an error and now when I go to use it it is not giving me the option for bleeding brakes. I will try to attach pictures below. Running INPA on hp laptop with windows 10 64 bit. Thanks for your help.
    Dec 2018
    Corpus Christi
    2002 BMW Z3 M
    Posted by redmeat:
    2004 x5 e53 I repaired brake lines and need to bleed my abs brake system. I bought a cable off ebay and downloaded mikes easy official writemyessay software. When I down loaded it I got an error and now when I go to use it it is not giving me the option for bleeding brakes. I will try to attach pictures below. Running INPA on hp laptop with windows 10 64 bit. Thanks for your help.
    Hello @redmeat,
    I previously bled the system with a motive power bleeder. Though it seemed to me I might of got some air in the lines installing the BBK, as I noticed my brakes were incredibly firm after I proceeded with the INPA method. Could you please share some pictures so that I could help you out? Anyway, I'd recommend a thorough service check of the abs braking system. Because when you download a firmware and get an error, it is a very dangerous sign. Out of the blue, the abs system may have a glitch and lock one of the wheels.
  1. INPA not working on early 90's cars?
    By Rallyfinnen in forum Diagnostic Software
    Last Post: 05-24-2022, 11:23 AM
  2. INPA not working properly. ARS commission
    By rkreimer10 in forum Diagnostic Software
    Last Post: 10-25-2017, 07:02 PM
  3. INPA, NCS expert not working properly... Connection error??
    By samtheman48 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-26-2016, 12:56 PM
  4. INPA 5 works on some parts of 2004 E46 but not others
    By weenick in forum Diagnostic Software
    Last Post: 10-06-2016, 03:43 AM
  5. Weird - INPA/DIS works on 00 E39 but not my 01 E39
    By mkaehly in forum Diagnostic Software
    Last Post: 12-30-2011, 11:22 AM
