So earlier today I was driving around, and turned left onto a street. As soon as I finish the turn, my engine cut off, and I could hear a sort of chugging sound. The RPM needle hopped inbetween 1 and 2 while it turned off. The brake light turned on red and then stayed yellow, so did he dsc light. The “service engine soon” light followed shortly after. I slowly applied the brakes and shifted into Park. The lights where still on and I really don’t understand what happened. But I then tried turning it on again and there was a major delay. 7 minutes before this I had turned it on and everything was functioning normally. The engine, aside from having a longer delay, also struggles a bit to accelerate forward now.
If anyone can help I really appreciate you just let me know if I can be of assistance. Also I haven’t gotten the error codes but will do so in a day or two.
Edit
-it has also been raining moderately for the past two days. The curb did have a puddle. Right after I cleared it the engine cut off and the mentioned lights turned on aswell as the ignition delay
Edit2
-I got code p0335
Still don’t know how that connects to dsc and Brake light.
Was this at night? How many things running A/C, rear defrost, front defrost, seat heaters?
2005 330ci ZHP 6MT
2005 330i ZHP AT (Sold)
1989 325i
1990 318is
2014 328d X-drive
2017 VW Alltrack
Just the radio and headlights were on. Yes this was at night.
Ok, I had a similar issue happen last winter. Car started fine and I was warming it up at idle with about every damn thing on in the car, lights, heated seats defroster up front and rear. As it turned out the battery was a bit taxed due to small trips around that winter. Normally I would leave the car on a charger but had not done this in a while. Try giving the battery a good charge and see if the issue goes away, I think you may have a low battery. I had all the damn lights coming on as well as CEL, brakes you name it!
2005 330ci ZHP 6MT
1989 325i
1990 318is
2014 328d X-drive
2017 VW Alltrack
Thank you I’ll go ahead and do that
Scanning for codes should be your first step.
Any update, did getting a good charge resolve the issue?
2005 330ci ZHP 6MT
1989 325i
1990 318is
2014 328d X-drive
2017 VW Alltrack
Sorry I haven’t updated. I went to get the lights checked and there’s only one code p0335. I had the battery checked+alternator before that and everything was fine.
I’m looking into replacing the crankshaft position sensor but I don’t know the location of it. Is there any way you guys can help?
Good site for diagrams and part#'s:https://www.realoem.com/bmw/enUS/sho...diagId=11_2167
Install instructions:https://www.pelicanparts.com/BMW/tec...eplacement.htm
