Hello,
Found a connector with nothing attached to it directly behind the glovebox. Its taped around a factory harness with cloth tape. Does anyone know what this connector is for? Its in a 98 Z3 M.
Thanks,,
Factory Alarm and Keyless Entry System interface?
Ahh...makes sense. By keyless entry,,, does that mean that if I retrofit an aftermarket alarm system it can potentially unlock doors?
Yes, but find a quality one that plugs into that harness. Don't go to someone that will splice and cut up your wires, when factory already prewired everything.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
The keyless entry you choose depends on your budget. I've installed 3 of the el-cheapo ones, and all have worked well for years. They are about $17, with 2 fobs with batteries, but they have some disadvantages. First, they do not "double-lock" (I think that's the right term) the doors, so a person could unlock them if he could reach the inside door handle. Second, the instructions are poor, and require some savvy on your part. Still, for the price, they are great. Very easy to install once you figure out the wiring. The trick is to make it simple. Find some +12v, a ground, and figure out which wire "locks" and which wire "unlocks" the doors. I also have a 98 M, so maybe your colors are the same as mine. Here's the one I bought: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also, from my 2 year old memory, I don't think that thing in your picture is the one you need for this job.
Browse eBay...plenty of OEM keyless entry brains. Do your best to find one with the harness cable (green end IIRC) and alarm LED included, or else programming is a bit tedious. When you go thru the steps (comical when you come across them), the LED will tell you when you're in programming mode.
Finding a reasonably priced fob will be the bigger challenge. From my testing, only the BMW branded fob will work. There are Subaru fobs that look identical and have the same FCC ID. Those don't work.
Also, there is a connector under the brake booster that will accept the OEM siren. It's zip tied and a bit difficult to see, but it's grey and pretty obvious once you have the siren in hand. I was lucky to have my M Roadster as a frame of reference so found it in no time.
I bought the one referenced in post #5, but I didn't feel like splicing and wanted OEM.
Module: 82 11 1 496 445
Siren: 82 11 1 469 447 (others work too...I lengthened the wires and mounted the siren behind front bumper)
Fob: 82 11 1 469 448
Here's one with everything but the fob (black plug connects to the bit in your photo):
https://www.ebay.com/itm/BMW-E36-OEM...S!-1:rk:3:pf:0
Nathan in Denver
The fobs are NLA so you'll have to find one on eBay or in the forum classifieds
I may have a complete setup here with the two button fob if you are interested. I'll have to dig it out which might take a day or two. I also have a spare harness I believe.
I also have a couple BMW 2 button key fobs extra I would consider selling too.
Also, be aware that there were 2 versions of the alarm, 2 button round-ish fob, and older rectangle 3 button fob. THe unit looks the same, plugs in to the car the same and uses the same Alarm LED and Siren, but the fob, harness and brain are different. Fob and brain FCC ID need to match (technically, they'll be one number apart)
1998 Z3 1.9L Dinan Stage 3.
Pm sent.
just too a quick look. might not have the full kit, as I think I tossed it into an ebay lot of parts I sold earlier this year.
