Results 1 to 13 of 13
Thread: Fast Blinkers/turn signals
    Aug 2017
    Memphis
    2002 3.0 Z3
    I have a 2002 Z3 3.0, my blinkers/turn signals work fine when I have my head lights turned off. But when I turn my headlights and dash lights on and use my turn signals they blink much faster than normal. But only when lights are on. Any Ideas?
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by Roscoe458 View Post
    ... my blinkers/turn signals work fine when I have my head lights turned off. But when I turn my headlights and dash lights on and use my turn signals they blink much faster than normal. But only when lights are on. Any Ideas?
    When you walk around the car and look, do all your head lights and turn signal lights work?
    BMW MOA 696, BMW CCA 1405
    Jan 2018
    Ocala, Florida, USA
    2001 Z3 Roadster 2.5 M54
    I had a similar issue with my Chevy van a few years ago. First the right blinker started blinking fast, left blinker was OK. Then the left blinker started blinking fast so now both were fast. Typically a light bulb issue but not in this case as all lamps were good. Turned out to be the flasher unit.
    Sep 2017
    Northeast
    2001 M Roadster
    I had the same exact issue on my 2001 m roadster and a winded thread with bunch of smart ass remarks got to love the members of this board and their sense of humor. Anyways, it ended up being loose connection in the headlight. Just reconnect all one at a time, starting in the front and move to the back while keeping blinkers on and see which one is loose. I literally just wiggled the cable and it improved. There is none conducting grease you can pick up at your local hardware or auto store to seal and improve connectivity.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by DimrBimmer View Post
    There is electrisity conducting grease you can pick up at your local store to seal and improve connectivity.
    Dialectic grease is a non conductive grease that keeps O2 and moisture away from electrical contacts.
    Sep 2017
    Northeast
    2001 M Roadster
    Quote Originally Posted by bluptgm3 View Post
    Dialectic grease is a non conductive grease the keeps O2 and moisture away from electrical contacts.
    What he said
    Jul 2016
    Ma
    none yet
    I seem to recall a car I had once that if a fuse was blown or a bulb was out the turn signal on the dash would flash rapidly. It may have been my 1973 2002.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Vintage42 View Post
    A simple but unanswered question.
    Aug 2017
    Memphis
    2002 3.0 Z3
    Sorry! Yes, all lights work as they should. Just when lights are on the signals blink very fast.
    Sep 2012
    G'ville,FL.
    2000 Z3 2.8L/2003 530i
    Mine does the same thing.... my fix,I stopped driving at night.
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    Any ground connections to the body or other metal components could also be suspect, especially if there’s any obvious corrosion.
    Sep 2017
    Northeast
    2001 M Roadster
    But seriously, I had same exact issue and posted about it. I got enough magic smoke responses, so let me spare you from those. Go around the car and reconnect all you bulb connectors starting from the front, testing blinkers with lights on each time to confirm if it’s fixed.
    Oct 2018
    West Bend, WI
    Sounds like a good place to start.
  1. Very fast blinking turn signals?
    By jaredmac11 in forum 1975 - 1983 (E21)
    Last Post: 02-08-2019, 07:21 PM
  2. Fast blinking turn signal, bulbs are OK
    By Sundancer in forum 8 Series (E31)
    Last Post: 08-12-2018, 10:07 AM
  3. Blinker/Turn Signals Lights
    By Rony94 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-04-2015, 08:54 AM
  4. Super fast left turn signal, and right low beam out?
    By Silverdogz in forum 1983 - 1991 (E30)
    Last Post: 02-03-2013, 09:49 AM
  5. fast flashing turn signal
    By lilrobo in forum 1988 - 1996 (E34)
    Last Post: 08-02-2010, 11:15 PM
