Today, I was going to finish getting the engine ready to go back in the car. All that needed to be done was VANOS and valve cover. Well I start trying to get the main exhaust sprocket with the lower chain on. Too short. So I figure maybe a link is caught up somewhere and it needed some whipping while slightly rotating the crank. That didnt do it.. Finally I remove the oil pan to see if anything is caught up and it is seated on the sprocket perfectly. This is a new IWIS chain. I mean we are talking a centimeter too short. I'm completely at a loss right now on what to do. The engine would have been ready to boost after the vanos timing and now I feel like I'm 10 steps back.
Has anyone had this issue? Everything looks seated correctly.
CURRENT: LimeRockParkEdition E92 M3 - BSM/Silverstone E70 X5M - AW/Dove E36 M3
PAST: Techno/Dove E36 M3 - Techno/Dove E36 M3 - LSB/Black E46 M3
You didn't mention it so, the tensioner is out right?
Yes the tensioner is out. Head just went on about 5 days ago with the CES copper combo gasket kit. Double checked to make sure lifter trays are seated properly. I replaced the oil pump chain and fits perfect. Haven't gotten to try the upper chain yet..
If you are curious on the chain I received it is P/N 11 31 1 432 176
I just did one for someone else this weekend with a cutring and spacer and the exhaust sprocket was really hard to get on even with a used chain.
Finally got it on, just cost a busted thumb. If I were doing this again I would NOT get a new lower chain. Now I get to do this process a few more times tomorrow to get it aligned. Thanks for the input guys.
On another note, Is it okay to reuse the oil pan gasket? It was just installed and torqued, no heat cycles. Really don't want to have this bad boy leaking.
Should be fine. Make sure to use silicone in the correct areas.
Another thing is this chain is TIGHT. no play at all.
This is just one of the many reasons I'm not a fan of the head spacer idea.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
Just the rear main/timing cover areas
yup, I was advised otherwise to use Indian head shellac on my entire oil pan gasket. Was told it would seal those bmw knotches as well.. It DID NOT. my oil pan leaks. trial and error. you live and learn. RTV only in those factory required areas on the pan and timing chain case as well. At least it sealed the hell out of my headgasket.
I didn't have a problem with my chain?
Probably a bit loose from higher miles
Engine is timed, hopefully correctly. Spun it twice and blocks drop on @ TDC. With the copper spacer is the timing procedure with the main exhaust sprocket the same? VANOS operating wise. Main exhaust sprocket aligned far left for bolts? Chain tensioner literally does nothing here. This chain is extremely tight.
VANOS is installed and all thats needed is the valver cover and oil pan now.
