Results 1 to 17 of 17
Thread: Z3 EWS Communication Issue (AK90 flash)
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    This is the first time in a very long time I have been stumped with an electronic issue on one of my cars.
    I recently changed the ZCS on my EWS module and once I wrote the new ZCS with NCSExpert I lost communication with the EWS module and could not connect to it whatsoever.
    I made a copy of the MCU with AK90 before writing the MCU flash from when I first bought the car.
    Still could not connect to the EWS no matter what I tried. INPA, DIS, Tool32, etc.
    I decided to write the MCU flash I backed up that had the new ZCS. Not sure what happened, but was able to communicate with EWS with INPA, DIS and Tool32. Was able to start it once. After turning the ignition off I lost communication again and have not been able to connect to the EWS module since. I have flashed the MCU with AK90 back and forth between the two dumps I have and it is not working. No fuses are blown. Everything else seems to be working properly.
    Currently have an error in DME "EWS/DWA...". All software reports no response from the control unit.
    Any ideas?
    South Carolina
    2004 330 vert 2004 X5
    When you used the AK90 what did you use to clean off the resin off the EWS circuit board? Just taking a guess here but I'm thinking you damaged the EWS board.
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    I carefully scraped it off with the edge of a knife. I don't think this caused an issue as I did that two years ago and have driven the car since then. When I took the module out the other day I didn't have to clean the pins.
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    Any thoughts? I'm thinking about buying a used EWS2 unit and reflashing it to see if that works.
    No communication with mine whatsoever. No idea what the issue is.
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    Anyone else ever had a similar issue?
    Jul 2004
    Houston, TX
    36 Cylinders
    I would clone your old ews into a used one. Sounds like you had a hardware failure after coding, which is weird in itself.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Prague, Czech Republic, E
    11/98 E39 535i V8 M62TU
    Which ews module and DME do you have? I have a few ideas. Send me a PM, I will give you my e-mail to send me the original file read by AK90. I will try to help.
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    Sent you a PM. I am currently waiting on a used EWS2 unit I purchased on eBay.
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    I fixed my issue. Long story short fuse 31 was blown which is for the EWS.
    I had overlooked it several times, but after pulling it today I could see a small break in the filament.
    After replacing the fuseI was able to connect to my EWS. Still couldn't start the car so after following Fx323i's recommendation of unchecking the used keys in the EWS Editor and flashing the .bin back I was able to start the car after the keys resynchronized.
    IL
    2000 740i sport
    Quote Originally Posted by TC4 View Post
    Did this require re-writing the ews data back to the keys as well or they automatically pulled in the current stored rolling code after each keys first use?
    Sent from my SM-N960U using Tapatalk
    Jun 2015
    Vereinigte Staten
    E30, E36, E46
    The chips in the keys can't be reprogrammed as they are write once only.
    The key passwords are stored in the EWS from new. Unchecking the used box and reflashing the EWS forces the keys to resynchronize with the EWS module.
    It works the opposite way. When you reset the keys random codes in ews, if everything else is verified, the ews stores the key's random code and then works with it as usually.
    Martin Voigts
    BMW cars indy and locksmith
    1997 E36 318iS Sierrarot
    2012 Ford Mondeo
    Jul 2004
    Houston, TX
    36 Cylinders
    It should not be an issue if you have a straight clone, without any successful engine run on it.. right?
    I have cloned plenty of EWS3, but I was under the impression that ews2 didn't have key rolling codes.
    -Abel
    On ews2, key-ews system is the same with ews3. The dme/dde-ews system is different. Also, some ews3 and ews4.3 work in ews2 mode.
    Martin Voigts
    2012 Ford Mondeo
    IL
    2000 740i sport
    Quote Originally Posted by Fx323i View Post
    Are you saying unchecking the key as a used key in the ews and re-writing it back to the ews will reset the key code for that key, which should allow that key to start the car? I have had a few rolling code key errors, where re-writing the EWS data to the Original EML style key(in its current key slot)allowed the car to start this way. Im trying to make sure I follow the correct procedure from you more experienced EWS guys...
    IL
    2000 740i sport
    Do they write to the next unused key slot if its a new virginized transponder?
    Purplecty: Your rewriting of keys should work too if the key belongs to the ews. I rather repair the data in the ews because many people are shipping the units to me for a repair so I do not need them to ship the keys, too (matter of trust of the customers in me and also our very poor postal service here). Nevertheless, in the ews you can check if the data written are correct. With the key you must trust the Write key OK tab. I also would recommend to rewrite the key with the data for the same position in the ews.
    Regarding writing to new unused transponders, it all depends on how many slots have been used. I personally never use the next slot because if anyone in the future would order the next key from BMW, it would have been on the same position. So I rather go from the other end if there is enough space, or use the position of knowingly lost key.
    Martin Voigts
    2012 Ford Mondeo
  1. Key/EWS/Ecu issues..
    By BSloss13 in forum 1991 - 1999 (E36)
    Last Post: 10-18-2008, 08:42 PM
  2. Please help - EWS (1) issue?
    By motorradfahrer in forum 1991 - 1999 (E36)
    Last Post: 12-25-2006, 10:17 PM
  3. Z3 98 Alarm issue
    By Tourniquet in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-28-2005, 02:24 AM
  4. purchasing a used z3-any reliability issues?
    By HksPwrsche in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-12-2005, 10:42 PM
  5. Z3 rack install issues
    By BigDog in forum 1992 - 1999 M3 (E36)
    Last Post: 03-02-2005, 02:21 PM
