has anyone replaced the front left differential bearing on an e53. my seal is starting to leak and there seems to be a little play in the bearing but Bavarian autosport does not even sell the bearing, only the seal.
Personally I would just replace the seal, there are no bearing part numbers listed. You would have to pull the bearing and check the number on it, the try to find the replacement
