Guys, I post on the E32 board but coming here for a little help. I have a friend with a 2008 M5. Not sure of E or F model he has but I do know it's a 10 cylinder. His fault codes with his code reader as well as his mechanic's is showing the reason for the ABS light is in fact a bad module. I know the best places to shop for E32 parts as I've owned mine since 1990. Can you put me in the right direction here. Used, rebuilt or new if necessary. I hear they can be as costly as three grand. Maybe you all know somebody parting out a car or a place that does. Thanks for your time on this. He's not a forum member here so I told him I'd check with you.
Jeff
1990 735I (Auto) E32 Feb 1990 to Present
1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
1983 733I (5 Speed) E23 April 1983 to Feb 1990
https://www.youtube.com/watch?v=2d4tHoHGaJo
https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
It’s an e60 and most likely it needs the szl cleaned. Also called steering angle sensor or clocking spring. That causes the most problems with dsc. If you want a better answer we need the actual codes.
