Results 1 to 2 of 2
Thread: ABS Module
    May 2012
    Boynton Beach, Florida
    1990 735I (E32) M30
    ABS Module
    Guys, I post on the E32 board but coming here for a little help. I have a friend with a 2008 M5. Not sure of E or F model he has but I do know it's a 10 cylinder. His fault codes with his code reader as well as his mechanic's is showing the reason for the ABS light is in fact a bad module. I know the best places to shop for E32 parts as I've owned mine since 1990. Can you put me in the right direction here. Used, rebuilt or new if necessary. I hear they can be as costly as three grand. Maybe you all know somebody parting out a car or a place that does. Thanks for your time on this. He's not a forum member here so I told him I'd check with you.
    Jeff
    1990 735I (Auto) E32 Feb 1990 to Present
    1996 Z3 Roadster (5 Speed) E36/7 Jan 1999 to Dec 1999
    1983 733I (5 Speed) E23 April 1983 to Feb 1990
    https://www.youtube.com/watch?v=2d4tHoHGaJo
    https://1drv.ms/v/s!Av20xCMMocSsyEpl...h_oOk?e=ekIcAT
    Mar 2013
    Sonora, ca
    2001 740il
    It’s an e60 and most likely it needs the szl cleaned. Also called steering angle sensor or clocking spring. That causes the most problems with dsc. If you want a better answer we need the actual codes.
  1. bmw ECUs, ABS modules, throttle body, MAF sensors...CHEAP
    By wethvento in forum BMW Parts For Sale
    Last Post: 08-24-2005, 01:15 AM
  2. WTB: ABS Module
    By AvusRacer in forum BMW Parts Wanted
    Last Post: 12-11-2004, 10:31 PM
  3. ABS module location?
    By techno550 in forum 1991 - 1999 (E36)
    Last Post: 06-24-2004, 07:21 PM
  4. DME 95 m3 - ABS module 95 m3
    By DupaHead in forum BMW Parts For Sale
    Last Post: 10-18-2002, 11:40 AM
  5. DME 95 m3 - ABS MOdule 95 m3
    By DupaHead in forum 1992 - 1999 M3 (E36)
    Last Post: 10-18-2002, 11:39 AM
