Hope im not posting in the wrong place.
So i had a pre purchase check up done on a 2005 320 120kw, and they found some fault codes, are these of big concern? How much would getting rid of these cost approximately? Thanks in advance!
- A6CF JBE: AUC sensor Current
- A6DF JBE: Mirror/spray-nozzle heating, right Current
- A6D1 JBE: Auxiliary-water pump
- 4212 DDE: Glow plug, cylinder 1
- 4222 DDE: Glow plug, cylinder 2
- 4232 DDE: Glow plug, cylinder 3
- 4242 DDE: Glow plug, cylinder 4
- 4A27 DDE: Intelligent battery sensor, communication
- 9520 DSC: Steering column switching centre, multifunction
I would suggest simply clearing those codes and see if any return. Codes like the ones for all 4 glow plugs may indicate work had been done on the glow system and codes were never cleared.
Sent from my iPad using Tapatalk
