Hi all, first time post and new member so I hope this is the right place for this post. I have a bmw x3 (e83) 2.0d. I hav air gap fault on front right wheel. I have changed the abs sensor, had wheel bearing done, drive shaft done, abs module checked, actuator checked and transfer case done by previous owner trying to sort the same issue with no avail. Is it possible the steering angle sensor could cause this, I have 4x4, brake and abs light illuminating at the same time at roughly 7mph but they then go out when I sit at steady speeds, I have been on a long journey and after roughly 1hr it repaired itself driving faultless and once ignition was off and back on the problem was back. I've checked the 4 sensors with a meter and all read the same and followed the harness back and their are no split wires, the only thing not been touched is the steering angle sensor and I've read that this also reads wheel speed for traction so could this be the fault, looking to repair this myself, I have all the tools, icarsoft reader and laptop with bmw software. Hope someone can help it would be appreciated. 18months now I'm at my last with it
