Well here I am again, trying to sell my E36 for no particular reason! Honestly have zero complaints with this car, excellent running car. Extremely proven to hold great power and go on any long trips that I might make it endure. No, I'm not selling it to please the wife, kids or anything else for that matter so my price is set FIRMLY based on current layout / condition of the car. I may be able to make some exceptions but likely not. Pictures are after all the technical parts lists etc.
Basics to the car:
~ 1995 318IS
~Miles on chassis 165k
~Minty clean shell
~Clean title
~Car made 620WHP / 590WTRQ
~100% 1999 M3 Swapped (meaning NOTHING and I mean NOTHING is left from the 318IS)
~To weed out most people I'll set the price tag HERE, 12k. If you want to keep reading great! (It's a well setup car!)
Suspension:
~ST XTA Coils Single adjustable Shocks (camber plates)
~Every Ball Join is new (not going into details on that just every balljoint style is new including Rear trailing arms)
~SLR Speed adjustable Lolipops (Caster adjustments)
~ECS Rear adjustable control arms
~Stock swaybars
~Powerflex FIXXED version (Rear subframe)
~Poly Rtabs
~REINFORCED rear sub-frame mounts AND RTAB pockets from Condor speed shop (weld-ins)
ENGINE / TURBO STUFF:
~TURBO SETUP HAS BEEN GOING FOR APRX. 20k MILES! (Cams have 5k on them, turbo has 5k on it rest has 20k, Engine with new gaskets 5k ago pulled it so why not)
~S52 Engine
~Schrick 264/256 Cams
~Vac Motorsport Dual Valve Springs retainers and keepers
~Valves gone through and spec'd (also lapped and new seals)
~CES Cutring copper spacer combo with ARP Studs
~Every gasket / Seal is new
~Bottom mount Twinscroll manifold
~Genuine Tial 44mm Wastegate
~Custom Borg Warner 64mm Turbo (Still uses cast aluminum compressor)
~Custom 3.5" Stainless Turbo back exhaust into 4" Vibrant stealth muffler DUAL TIP!
~Treadstone Intercooler
~TRM 60LB Blow-thru tune
~AEM Wideband Gauge
~Autometer Vac / Boost gauge
~340LPH Fuel pump hardwired
~Adjustable FPR
~Underdrive pullies
~New power steering pump / rack / lines / resivour
~New alternator
~New water pump
~New belt / idlers
Drivetrain:
~Zf320 Pulled out of 85k Mile 528
~CES 210MM Bulletproof LSD Conversion! (You can't kill them!)
~Stock driveshaft
~FX Clutch (holding fine, CANNOT CONFIRM WITH DRAG RADIALS I DON'T USE THESE.)
BRAKES:
~Porsche 996 Conversion front and back with stainless steel lines.
~Uses the 345mm front rotor (E46 M3 CSL)
~Duct plates on hubs but with no venting pipes currently (Can't get them hot enough anyways to use them)
Body:
~Semi Wire tucked / Semi Shaved and painted engine bay (looks awesome!)
~This is where I may loose everyone lol!
~Chassis is totally straight with hardly any door dings
~75MM Rear fender flares
~55MM Front fender flares
~Multi Colored M Style components because I've not got quite around to painting it yet, although I will if it does not sell just ran out of steam to do anything on it
~Keep in mind this is not your pick-up your wife car, unless your wife is a complete badass.
~M style interior as well, Driver vader has zero rips but is getting warn down. Passenger vader is fine.
Okay enough talk here are some pictures. If you are interested I'm an open book, I will tell you EVERYTHING about this whole car, I've touched every single square inch of it. So, with all this on the table I truly think it's worth what I'm asking. Hope you enjoy, the car is as solid as them come. I understand the cosmetic part with mismatching paint is a turnoff, like I've said I wanted to get around to it eventually.
Seems like a LOT of car for the asking price. Just curious, heat or AC? What does it have interior wise?
E36 M3 Interior (Power Vaders.) The heat works as it should, The A.C COULD be hooked quite easily. Just never really cared too. It would just inhibit the Intake for the turbo some. Thanks, honestly, mechanically the car is "turn key" setup.
Ugh, I want to not want this.
Comes with 2 sets of tires too lol. 200TW track and 300Tw cruisers. Both less than 3k miles. Oops forgot wheel specs in ad, 18x10 with 275/35/18 Squared.
Seems like a solid car for the price.
I agree with pMak26...I want to not want this!!!
Seriously thinking of taking her.
She's a beast, I can get more photos if you like. Messaged you!
Pm sent
What road is that in the pic with the S2000s?
Highway 129, AKA Deals Gap, AKA The tail of the dragon.
How are you liking those federal tires?
Which flares on the car?
― George Orwell
Rsrr tires work very well, noisey but they get the job done. Flares are just ebay style, but they fit very well imo.
Any video? pics of interior?
Did you autocross it? or just built to hoon on the street?
Thanks,Carl.
Pm'd
PM'd
bump, this thing is dope. Please pm me just to talk about car, I would like to do similar turbo setup on my s52
Last call! Shes mine for yet ANOTHER season after this month. Wouldn't care if you had 25k! Lol.
Upstate NY? Where abouts do you live? I live in Syracuse. That is one sweet car for the asking price, wish I could justify having a toy around right now
Is this still for sale?
Pm'd
