BMW of Bloomfield
Results 1 to 21 of 21
Thread: Turbo E36 For Sale! (details inside)
    Mar 2013
    Upstate NY
    M3
    Well here I am again, trying to sell my E36 for no particular reason! Honestly have zero complaints with this car, excellent running car. Extremely proven to hold great power and go on any long trips that I might make it endure. No, I'm not selling it to please the wife, kids or anything else for that matter so my price is set FIRMLY based on current layout / condition of the car. I may be able to make some exceptions but likely not. Pictures are after all the technical parts lists etc.
    Basics to the car:
    ~ 1995 318IS
    ~Miles on chassis 165k
    ~Minty clean shell
    ~Clean title
    ~Car made 620WHP / 590WTRQ
    ~100% 1999 M3 Swapped (meaning NOTHING and I mean NOTHING is left from the 318IS)
    ~To weed out most people I'll set the price tag HERE, 12k. If you want to keep reading great! (It's a well setup car!)
    Suspension:
    ~ST XTA Coils Single adjustable Shocks (camber plates)
    ~Every Ball Join is new (not going into details on that just every balljoint style is new including Rear trailing arms)
    ~SLR Speed adjustable Lolipops (Caster adjustments)
    ~ECS Rear adjustable control arms
    ~Stock swaybars
    ~Powerflex FIXXED version (Rear subframe)
    ~Poly Rtabs
    ~REINFORCED rear sub-frame mounts AND RTAB pockets from Condor speed shop (weld-ins)
    ENGINE / TURBO STUFF:
    ~TURBO SETUP HAS BEEN GOING FOR APRX. 20k MILES! (Cams have 5k on them, turbo has 5k on it rest has 20k, Engine with new gaskets 5k ago pulled it so why not)
    ~S52 Engine
    ~Schrick 264/256 Cams
    ~Vac Motorsport Dual Valve Springs retainers and keepers
    ~Valves gone through and spec'd (also lapped and new seals)
    ~CES Cutring copper spacer combo with ARP Studs
    ~Every gasket / Seal is new
    ~Bottom mount Twinscroll manifold
    ~Genuine Tial 44mm Wastegate
    ~Custom Borg Warner 64mm Turbo (Still uses cast aluminum compressor)
    ~Custom 3.5" Stainless Turbo back exhaust into 4" Vibrant stealth muffler DUAL TIP!
    ~Treadstone Intercooler
    ~TRM 60LB Blow-thru tune
    ~AEM Wideband Gauge
    ~Autometer Vac / Boost gauge
    ~340LPH Fuel pump hardwired
    ~Adjustable FPR
    ~Underdrive pullies
    ~New power steering pump / rack / lines / resivour
    ~New alternator
    ~New water pump
    ~New belt / idlers
    Drivetrain:
    ~Zf320 Pulled out of 85k Mile 528
    ~CES 210MM Bulletproof LSD Conversion! (You can't kill them!)
    ~Stock driveshaft
    ~FX Clutch (holding fine, CANNOT CONFIRM WITH DRAG RADIALS I DON'T USE THESE.)
    BRAKES:
    ~Porsche 996 Conversion front and back with stainless steel lines.
    ~Uses the 345mm front rotor (E46 M3 CSL)
    ~Duct plates on hubs but with no venting pipes currently (Can't get them hot enough anyways to use them)
    Body:
    ~Semi Wire tucked / Semi Shaved and painted engine bay (looks awesome!)
    ~This is where I may loose everyone lol!
    ~Chassis is totally straight with hardly any door dings
    ~75MM Rear fender flares
    ~55MM Front fender flares
    ~Multi Colored M Style components because I've not got quite around to painting it yet, although I will if it does not sell just ran out of steam to do anything on it
    ~Keep in mind this is not your pick-up your wife car, unless your wife is a complete badass.
    ~M style interior as well, Driver vader has zero rips but is getting warn down. Passenger vader is fine.
    Okay enough talk here are some pictures. If you are interested I'm an open book, I will tell you EVERYTHING about this whole car, I've touched every single square inch of it. So, with all this on the table I truly think it's worth what I'm asking. Hope you enjoy, the car is as solid as them come. I understand the cosmetic part with mismatching paint is a turnoff, like I've said I wanted to get around to it eventually.
    Nov 2008
    nnj
    Vipers, e46m
    Seems like a LOT of car for the asking price. Just curious, heat or AC? What does it have interior wise?
    Mar 2013
    Upstate NY
    M3
    E36 M3 Interior (Power Vaders.) The heat works as it should, The A.C COULD be hooked quite easily. Just never really cared too. It would just inhibit the Intake for the turbo some. Thanks, honestly, mechanically the car is "turn key" setup.
    Nov 2008
    nnj
    Vipers, e46m
    Ugh, I want to not want this.
    Mar 2013
    Upstate NY
    M3
    Comes with 2 sets of tires too lol. 200TW track and 300Tw cruisers. Both less than 3k miles. Oops forgot wheel specs in ad, 18x10 with 275/35/18 Squared.
    Feb 2016
    Rogers AR
    1995 BMW M3
    Seems like a solid car for the price.
    I agree with pMak26...I want to not want this!!!
    Where I wanna
    bmws ;)
    Seriously thinking of taking her.
    Mar 2013
    Upstate NY
    M3
    She's a beast, I can get more photos if you like. Messaged you!
    Jul 2004
    TC
    '98 M3
    Pm sent
    Feb 2017
    Boston
    96 M3
    What road is that in the pic with the S2000s?
    Mar 2013
    Upstate NY
    M3
    Highway 129, AKA Deals Gap, AKA The tail of the dragon.
    NY
    skateboard
    How are you liking those federal tires?
    Which flares on the car?
    ― George Orwell
    Mar 2013
    Upstate NY
    M3
    Rsrr tires work very well, noisey but they get the job done. Flares are just ebay style, but they fit very well imo.
    OH
    e46 bmw
    Any video? pics of interior?
    Did you autocross it? or just built to hoon on the street?
    Thanks,Carl.
    Mar 2013
    Upstate NY
    M3
    Pm'd
    Dec 2018
    Louisville KY
    16 Frontier PRO-4x
    PM'd
    Mar 2018
    Raleigh, NC
    99 m3 coupe, 92 325i
    bump, this thing is dope. Please pm me just to talk about car, I would like to do similar turbo setup on my s52
    Mar 2013
    Upstate NY
    M3
    Last call! Shes mine for yet ANOTHER season after this month. Wouldn't care if you had 25k! Lol.
    Sep 2018
    Central New York
    '97 328i/4/5 Sport
    Upstate NY? Where abouts do you live? I live in Syracuse. That is one sweet car for the asking price, wish I could justify having a toy around right now
    Aug 2011
    Stafford Springs, CT
    98 M3
    Is this still for sale?
    Mar 2013
    Upstate NY
    M3
    Pm'd
  1. E36 Technique Tuning E36 turbo manifold for sale
    By EddieH in forum Race Cars & Track Parts
    Last Post: 10-25-2011, 04:42 PM
  2. Looking for local test cars E36/E46/Z3.... details inside
    By MotionMotorsport in forum New England - US
    Last Post: 03-18-2011, 05:01 PM
  3. put my linea corsa up for sale, details inside.
    By razahyde in forum 1996 - 2003 (E39)
    Last Post: 10-20-2008, 01:59 PM
  4. EUROPROJEKTZ- Turbo e36 M3 video content inside
    By M3Style95 in forum BMW Rides & Events
    Last Post: 01-25-2008, 02:59 PM
  5. Turbo E36 for sale
    By base146ball in forum BMW Cars For Sale / Wanted
    Last Post: 01-27-2007, 01:24 PM
