Results 1 to 4 of 4
Thread: Repalce rear speed sensor issues
    west new york,nj
    328i
    From abs coñtrol unit I found rear sensor is bad. But I have difficulty to
    1. Open the little connector box attached to the chassis. It seems should be opened from the below but it doesn't open. Couldn't find any info about it.
    2. The screw is too rusty to unscrew with wd40. Should I buy a torch? My mechanic used torch to burn then hammer it for other parts.
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Connector box will open (and likely break) if you work a flat head screwdriver around. Look closer and you can see the tabs that keep it shut.
    ABS sensors are notoriously difficult to get out. Many people drill them out. Search here and/or Google as people have come up with all sorts of methods to varying degrees of success.
    Good luck
    Apr 2015
    Tennessee
    1998 BMW 328i
    Ive had the best luck using a torch. Get it hot, spray penetrating oil on it, tap it with a hammer to aid in breaking it loose. Repeat these steps until it comes out.
    west new york,nj
    328i
    Eventually went to the mechanics to learn some tricks. He used twist socket to crank it open. Also did rear brake pad replacement as my tool get blocked by the shocks. Replaced one sensor and ABS warning light is gone. Total bill is $75 for 2 hours. Not too bad.
  1. Removing wheel speed sensor issue
    By flyfishvt in forum 1991 - 1999 (E36)
    Last Post: 08-28-2012, 05:02 PM
  2. Rear speed sensor on Touring
    By xpcgamer in forum 1996 - 2003 (E39)
    Last Post: 03-01-2009, 11:13 AM
  3. Please help with speed sensor issue on blown car !!
    By Greekthang in forum Forced Induction
    Last Post: 01-04-2008, 10:40 AM
  4. ABS rear speed sensor 02' 325ci PLEASE HELP!
    By cnpdmb in forum 1999 - 2006 (E46)
    Last Post: 04-29-2007, 09:44 PM
  5. Rear parking sensor issue
    By Five40i in forum 1996 - 2003 (E39)
    Last Post: 01-24-2007, 10:52 PM
