Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Thread: Quick Jack
  1. #26
    Wisconsin
    1995 BMW M3
    Love Mine!!!
  2. #27
    FL
    are slow.
    Quote Originally Posted by TH3 Shifty View Post
    anyone use the MAXjax? ive wanted that one for a while, cheapest place to get it is directly from Maxjax for $1899
    https://www.maxjaxusa.com/buy-purcha...d-package.html
    Hmm, completely different system. This needs to be bolted into a concrete slab, their manual says it must be 4" thick, but I would feel much more comfortable with a slab being 6" thick.
    Looks like a nice system.
    -Dr. Seuss
  3. #28
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    As we frequently have earthquakes here in Japan, I made the garage concrete with iron bar/mesh enforced and much thicker concrete than the 4" required. I also made a special cross bar between the 2 posts, you can see here where we discussed about the MaxJax in detail, also some small probs in the beginning when I installed it first time, 1 connector was not threaded etc. https://www.bimmerforums.com/forum/s...ghlight=MaxJax
    Actually I bought 2 at the same time then, the other one for a friend, his one also had some probs, pics in here, found some iron/metal pieces inside the quick connect valve from their drilling the threaded connections into the columns, were not removed in the China factory, causing uneven hydraulic fluid flow + lifting of the 2 poles. Repaired/cleaned it and installed new quick connector valves, since then also no probs. I have my one now since 2011, use it several times/month. Would buy it again.
    Key words: portability, compact storage, convenience, with a minimum ceiling height of 8 feet, it will fit in just about any home garage, with built-in wheels that allows you to use the lift when you need it, then store it out of the way when not in use.
    Quality control should be better, see my posts in above link and you find more when searching the net, the lift is made in China, but these probs are repairable. Leaks on my unit after many years use can come, and are repairable so far. Apparently they now also use U.S. electric motors for the hydraulic unit. After sales service is fine, so far technical support was good, when I contacted them with the problem I had to solve with the defective quick connection valves.
  4. #29
    Sep 2002
    Vancouver
    98 M3
    A local guy just had his quick jack drop his buddies civic while they were adjusting the coilovers. Luckily no one under the car. One side fell.
    - 98 m3, techno/anthrazit cloth, 124k and officially worthless - 89 m3, alpine/black 143k and officially old - 2000 323it, tiag/grey, 169k and officially boring
  5. #30
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Quote Originally Posted by notMpowered View Post
    For that to happen, BOTH safety bars would have fail or user error. Sometimes I do think about keeping some jack stands underneath just in case, but I just don't see this happening if being used correctly
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  6. #31
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by BMWManiac View Post
    He said that only side failed/fell. That being said, the only time I've seen something like this happen on a hydraulic jack (mainly a 2-post) is when the mechanical locks were not engaged but the car was left resting on the hydraulic pressure (cylinder). Once a line blows, fluid shoots out and the car's weight slams on the lock shearing it.
  7. #32
    Dec 2018
    The Couch
    2017 Mustang GT
    I don't see one side collapsing unless the safety locks were not engaged properly.
  8. #33
    Jan 2005
    Japan
    On the MaxJax I have and probably also on all other hydraulic lifts there are mechanical solid steel safety lock bars capable of holding three times the rated lifting capacity. one should stick them into the post = lift the car a bit higher than the holes are for the mechanical safety bars, insert the bars, release hydraulic pressure, the car moves slowly down till it rests on the bars on the post.
    Not using the safety bars is really dangerous.
  9. #34
    Feb 2002
    Orlando, FL
    Quote Originally Posted by NoRon View Post
    With the quickjack, you really have to watch when you go past the safety notches and then lower it to make sure both safety levers have passed and that the latch itself haw flipped to catch onto the latches. I know I watch and hold the down button for a couple of seconds to make sure, and then visually verify
  10. #35
    Apr 2008
    New Zealand
    1996 BMW M3-28i
    I love my Quickjacks. I dont have the space or concrete strength at home for a proper hoist, so Quickjack was my only option (we also have far less options here in NZ than in the US). I can also confirm there is no way they could drop one side, or at all, if operated correctly. Once its on the lock bars, and off the hydraulics, its solid as a rock, see the test videos above. Its easily paid for itself with how much I have used it.
  11. #36
    Oct 2007
    Orange County
    M3/4/5, SL65, GS350
    I just got one of the 5000lb lifts and tried it out today for the first time. A few questions....
    The rubber blocks hit the front jack points way before they hit in the rear. When the front blocks were snug against the car, there was probably one to two inches of space between the car and the rear pads. Normal?
    I had to remove those little black plastic pieces that hang down in front of the rear tires, otherwise they were getting crushed by the frame of the jacks. I’m surprised nobody has mentioned this, it is going to be annoying having to take them off every time.
    Several of my fittings are leaking, how much did you guys tighten them?
    Mine go up a little uneven, so when one side has the lock engaged, the other side is slightly past it. Normal?
  12. #37
    FL
    are slow.
    Sivikvtec, are you referring to the wind deflectors below the side skirts? You can use a hockey puck or a small piece of 2x4, 2x6 or similar wood there.
    It should be tightened fairly snug. I imagine around 30-35ft lbs. The manual says to use teflon tape, but I used pipe dope on all of them (careful to only get a thin amount on the threads) and I've never seen a drop of fluid.They are just hydraulic hoses, the rated pressure on both the fittings and hoses is many times the actual pressure seen.
    Page 21:
    https://www.quickjack.com/downloads/...J-Dec-2018.pdf
    For anyone interested; I noticed Homedepot has the 7,000lb model on sale for $1159. This is the lowest I've ever seen it for:
    https://www.homedepot.com/p/QuickJac...110V/309646718
    That's $440 off the normal price. Pretty solid deal.
    -Dr. Seuss
  13. #38
    Feb 2002
    Orlando, FL
    Damn, I would definitely buy the 7k model for that price! Probably should have went that route anyways just because I also have a large SUV!
    None of my fittings leak fluid, but the air canisters need more from time to time. Make sure you check the pressure every 2 seconds or so because it fills up really fast to 50 psi!
    I dont remove my wind deflectors and dont seem to have an issue. I place my block perpendicular where the jack points are and its fine
  14. #39
    Oct 2007
    Orange County
    M3/4/5, SL65, GS350
    Thanks for the info guys.
    What about the jack hitting the front jack points first, and then you have to continue raising it a few inches until it hits the rears? Is yours that way too?
    Also, are you just using one large block per corner? I couldn’t get the jack under the car with the medium and large blocks stacked on top of each other.
  15. #40
    Feb 2002
    Orlando, FL
    Quote Originally Posted by sivikvtec View Post
    Yes, my rears seem to touch after the fronts, so I'm guessing this is normal.
    I use one large block per corner.
  16. #41
    Oct 2005
    Auckland, New Zealand
    BMW 97 M3 3.2 Euro
    My E36 has rake front to rear
    Small rubber block at the front, large rubber block at the back
  1. Cheap Quick Jack At Costcos
    By torquepower85 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-04-2018, 03:58 PM
  2. Quick question how to put the seven on 4 jack stands..
    By geoprz in forum 1995 - 2001 (E38)
    Last Post: 03-09-2016, 05:25 PM
  3. Quick Q on Pittsburgh jack
    By luciano136 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-07-2012, 09:09 PM
  4. Quick Question: What is the best way to jack up the car?
    By dawgeatdawg in forum 1992 - 1999 M3 (E36)
    Last Post: 04-18-2009, 01:19 PM
  5. quick question! jacking up 97 328
    By Nice Guy Beck in forum 1991 - 1999 (E36)
    Last Post: 02-25-2006, 06:39 PM
