Results 1 to 3 of 3
Thread: VTG 54C8 Resistor Value Implausible
    Nov 2018
    Ollerton
    BMW X3
    I recently had to change the transfer case actuator as the motor failed, I used an aftermarket part that came with a new resistor fitted. Afterwards I went through the replaced procedure using DIS v57 but I could not clear the VTG 54C8 error - resistor value implausible and the 4x4 warning light stays on.
    I tried the reset resistor and replaced actuator operations and whilst the resistor value did reset to classification C the replaced actuator would not run. Instead I got the message cannot run without causing harm.
    As a last resort I put the original resistor back on but after resetting the classification (now H) it still says value implausible and won’t run the replaced actuator program. The 4x4 light is still on.
    Any help or advice welcome.
    Alexandria, VA
    E34M, E36M, E38
    I’ve got this same fault code. Did you get it resolved?
    2000 BMW 740iL | 225,XXX miles | VW MAF | Bavarian Auto Coils | Timing Chain and Guides DIY Complete | M60 Manifold | BDC Polished Throttle Body| Custom Tuned | Performance Gearing 3.46 LSD| Magnaflow mufflers |
    |1997 ///M3/2/5 | 104,XXX miles | Boston Green Metallic|2006 X3 3.0 SAV|121,XXX miles| Silver|
    Jan 2016
    Ca
    2001 525it
    Wel certainly if the part is not the exact replacement that could be a problem what is the deal about the resistor.
  1. vf charger kit, maf resistor values, higher=leaner
    By scrowley111 in forum Forced Induction
    Last Post: 10-07-2013, 05:59 PM
  2. Aux Fan Resistor Value
    By sirius815 in forum 1988 - 1996 (E34)
    Last Post: 05-03-2013, 09:26 AM
  3. SRS resistor value. Please and Thank you!
    By 98dinan3 in forum 1991 - 1999 (E36)
    Last Post: 11-07-2008, 10:16 AM
  4. Need aux fan resistor values, please...
    By M.Rad. in forum 1976 - 1989 (E24)
    Last Post: 06-27-2008, 03:49 PM
  5. Need rad fan resistor value
    By jayb79 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-18-2002, 10:59 PM
