Results 1 to 15 of 15
Thread: Camber arms question
    Dec 2012
    NC but always everywhere
    '99 BMW M3 Coupe (Dakar)
    I'm replacing my Bilstein sport shocks and Eibach sports springs with KW V2 adjustable coilovers. I'm a big fan of how my car rides and handles with its current setup however I just want it a bit lower. At the moment I have 15mm spacers in the front and either 10 or 12mm spacers in the rear (I'll have to go remind myself). With a full take of gas and a good compression my rear tires rub just a little bit. The fenders are rolled and could probably be rolled more but the paint on the car 8s original and in such good shape I'd be nervous to push my luck there.
    My question is that I think an option to lower the car without it rubbing is camber arms. Would I need them only for the rear? Assuming so but I'm sorta dumb at this stuff. I just want to make sure my fronts never rub. Terrified of popping a fender.
    Anyone have any suggestions on this? Also anyone have any suggestions on a good brand to go with?
    Nov 2013
    VA
    E36
    You can go with a cheap seat of camber arms from BW for the rear. For the front, they also sell a camber shim kit that you can use. You simply shim or add spacers where the front shock bolts up to the spindle. This will create additional camber so you don't rub as bad. If money isn't an issue, I would just buy front camber plates that are compatible with the kW's.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    I'm certainly not an expert here. Why don't you reduce the spacers in the rear?
    You can get adjustable rear camber arms (I run Turner adjustable rear camber arms).
    For the front, you need adjustable camber plates to sit on top of the strut.
    I'd being careful doing this piecemeal. Everything has to work in harmony.
    Dec 2012
    Quote Originally Posted by JitteryJoe View Post
    Yea, believe me I will make sure everything is done exactly right. I am WAY particular about this car.
    Thanks for the advice.
    Dec 2012
    Quote Originally Posted by bmw328m52 View Post
    Thank you
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    SPC arms in the rear will feel no different than stock since they use a rubber inner bushing and will give you plenty of camber adjustment. As for the front, the "best" way to adjust camber is with a good set of camber plates (strut mounts) like TC Kline or Vorshlag. The cheapest way is to swap your strut hats (Left to Right and Right to Left). Since you have a 99 M3, you'll end up around -3.5 to -4 degrees of camber which should be plenty. I have 245/40 tires on a 17x9 ET41 wheel at -3 degrees of camber up front and never rub unless I'm at full lock and hit a significant pothole, pretty much never.
    If you decide to roll the rears a little more, focus on the corner where the quarter panel meets the rear bumper. That's where they tend to rub the most. As for the paint, just heat it up with a heat gun. Not hot enough to burn you but hot enough where it's a little uncomfortable and go a little bit a time. The paint will be pliable.
    washington dc
    Avus Cosmos Calypso!
    you don't need aftermarket ones unless you want to run more than -2.0 degrees each side.
    Nov 2013
    VA
    E36
    I wouldn't run a coilover setup without front shims(camber plates preferred) or aftermarket rear control arms. It is a cheap mod to gain max adjust ability. Might as well do it while you're in there...
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    Camber is only one part of the equation when it comes to tire rub. Adding tons of negative camber isn't necessarily the best move in all circumstances (especially in the rear). You have to do it in the front, yes - and it can be beneficial there. But in the rear, adding negative camber might actually cause more tire rub. It depends on your combination of ride height, camber, toe, and wheel/tire package. A good starting point is to state the wheel size/width/offset and tire size/width that you're running front and rear.
    Dec 2012
    Quote Originally Posted by LockDots View Post
    Cool. Yea my rears just rub at the very top of the wheel arch.
    Dec 2012
    Quote Originally Posted by NoLastName View Post
    Just the standard setup with M Contours
    Dec 2012
    That's the plan. Want it all done in one swoop and it all done right.
    Feb 2009
    Mills River, NC
    Quote Originally Posted by Rooster20 View Post
    Ah. Sounds like you probably just need to remove the rear spacers then.
    Dec 2012
    Probably. They just look so much better installed.
    Dec 2012
    Would anyone be interested in the suspension that's currently on the car once I remove it? Only has around 15k miles on them. Cars never been driven in the rain so the parts have never even been wet. I dare say like new. 👍
  1. Turner Camber arm Question
    By CABimmer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-26-2014, 06:13 PM
  2. Rear camber arm question
    By Stephen Max in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 08-09-2012, 11:41 AM
  3. Specific SPC Rear Camber Arm Question....
    By LukeP in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-10-2008, 12:46 AM
  4. Adjustable rear camber arm question
    By e36ALPINE in forum 1992 - 1999 M3 (E36)
    Last Post: 06-05-2008, 10:38 AM
  5. Rear camber control arm question
    By NoSoup4U in forum Middle Atlantic - US
    Last Post: 06-28-2004, 06:10 PM
