Good morning all,
I tried to update the VDM (vertical dynamics module) of my E70 with Winkfp.
Comfort mode --> update ecu -->VDM70 ---> done
Winkfp gave a warning that the original ZUSB was 6785386 and that the new ZUSB is 6785396. Since I read that the ZUSB numbers change sometimes, I pressed OK and it started immediately programming the unit. Programming went well (progress bar to 100 percent) and after that it returned an error. I accidentally did not save this error.
In ISTA-D, the module is now shown red and also Winkfp cannot reach the module anymore.
How can I proceed with this? Can I flash it again with Winkfp in expert mode, and if so , with which software, because the new software was probably not intended for this ecu...
I looked manually in the database, but only 7 modules out of the 28 have a ZUSB number which is recognized by Winkfp... Is that normal?
Thanks in advance,
Hendrik Zeilstra.
