Results 1 to 2 of 2
Thread: E30 power steering and throttle
    Nov 2018
    canada
    1988 BMW 325i
    1988 325i - Power steering and throttle
    Hi guys. I just acquired a 1988 BMW 325i (4 door, North America - if it matters in the grand scheme of things)
    I am trying to figure out 2 things:
    1. Sometimes under acceleration (medium to hard) the engine cuts out (happened 3 times already). Other time (once), at speed (maintaining speed ~120kph) it would cut out. There is no jerk or anything, just dies and I put in neutral, restart and away i go. Would the be the TPS switch? if so, does anyone have the part # or are these units different based on the VIN?
    2. Need to replace the hoses and reservoir for the steering assembly (as a cleanup). As far as i could muster from looking at this forum and online, I need the reservoir, reservoir to pump assembly (banjo) and steering rack to reservoir assembly (banjo). There seem to be a few part numbers out there. Is there any way to make sure i get the right parts? Or they would fit as long as the model and year are correct for the part?
    2. b. at this time, should i replace the high pressure hose as well, or leave it be?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I would check the crank position sensor on the front of the engine, for the cut out
    No e30s again.
  1. E30 FS: e30 power steering hoses
    By N3nyongmini in forum Engines, Performance Parts & Software
    Last Post: 02-03-2014, 07:51 AM
  2. e30 power steering reservoir bracket
    By redefinedM3 in forum 1983 - 1991 (E30)
    Last Post: 04-01-2007, 04:39 PM
  3. E30 Power Steering Hose/Hose Connections Leak
    By E30tdf in forum 1983 - 1991 (E30)
    Last Post: 01-29-2006, 10:51 AM
  4. e30 Power Steering
    By Higgt00l in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-23-2005, 12:30 PM
  5. WTB: e30 power steering pump
    By Coldaccord in forum BMW Parts Wanted
    Last Post: 10-03-2003, 01:44 AM
