Results 1 to 8 of 8
Thread: Thud from rear end while sitting still
    Nov 2007
    Maryland
    None
    Replacing diff bolts and properly torquing reduced the thud.
    texas
    1992 BMW 325i (e36)
    Drive shaft guibo, mine did the same thing and progressively got worse until I changed it out
    texas
    1992 BMW 325i (e36)
    Mine was torn and would thud noise from the rear end
    Nov 2007
    Maryland
    None
    The Guibo was in perfect shape when I removed it. It wasn’t torn or shredding like I’ve heard of. Did you take a pic of it or no?
    texas
    1992 BMW 325i (e36)
    Quote Originally Posted by wolffbimmer View Post
    I don’t have a pic, I did but I think I deleted it. Mine was just worn out, at first the thud was just when I took off in 1st gear, then got progressively worse as time went on, I lifted it up and there was so much play in the guibo. My tranny mounts were pretty much shot also, but the thudding went away as soon as I swapped the guibo.
    Dec 2018
    West Sussex, UK
    E46 M3 Convertible
    Have you swapped to the new diff bolts? BMW updated them as they used to work loose. When your under the car looking at the diff from the rest it’s the 2 top right& left bolts, the 3rd bolt goes at the front of the diff.
    Nov 2007
    Maryland
    None
    Bolts replaced
    Dec 2018
    West Sussex, UK
    E46 M3 Convertible
    Good luck with dude hope you get it sorted ����
  1. 2014 M5 - Clicking or Ticking in Rear End while Cornering
    By HopelesslyAnnoy in forum 2010-2016 M5 & M6 (F10, F12, F13)
    Last Post: 10-23-2015, 11:03 PM
  2. thud from rear end of car + play in diff
    By Ryley in forum 1991 - 1999 (E36)
    Last Post: 08-07-2014, 02:03 PM
  3. Steering whell movement while sitting still
    By Casebrius in forum 1992 - 1999 M3 (E36)
    Last Post: 05-27-2005, 12:49 AM
  4. thud from rear end??
    By euro96 in forum 1991 - 1999 (E36)
    Last Post: 05-19-2005, 11:36 PM
  5. Replies: 13
    Last Post: 10-08-2004, 11:34 PM
