Results 1 to 17 of 17
Thread: Wheel and tire size selection specified in the owner's manual for a 96-99 Sedan
    Montreal, Quebec, Canada
    E46 330 ZHP, E36 328i
    Hi,
    I just purchased an M3 from out of province and need to get an inspection to plate it. The tires are too worn as is. They are the std staggered F225/45r17 & R245/40r17.
    The car did not come with the owner's manual so I'm looking for all the tires and wheels options that are recommended by the manufacturer in that manual. If someone that has the manual for the 96-99 M3 could take a picture of that page and post it below that would be awesome ?
    For winter, Tire Rack proposes a 205/55R16 package so it probably is an option from the manual but I would like to be sure.
    Thank you !
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    If you would like a hard copy;
    https://www.ecstuning.com/BMW-E36-M3...or%27s_Manual/
    Because the brakes are larger, I believe there are very few (if any?) 16" wheel options. If there are, they were discovered by owners, but I'm also being lazy and not pulling out my manual to answer this. Normally BMW will post applicable wheels in the ETK (so they can sell alternate sets when customers would ask). For the E36 M3, only 17" wheels are listed; http://www.realoem.com/bmw/enUS/part...6-BMW-M3&mg=36
    washington dc
    Avus Cosmos Calypso!
    The 17 sizes are correct for m3 stock. The snow size is 225/45/17 paired with 17x7.5s
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by scooper View Post
    Yes 1996+M3 was fit with 7.5 X 17 and 8.5 X 17 wheels, both ET41.
    There was a variant of the Contour wheel offered in 7 X 17 in ET 41 (36112227295) for use as wheels for winter tires
    I don’t believe there is a factory 16” wheel that fits over the front calipers.
    There are some 16” aftermarket wheels that I have heard do fit, however I do not know which ones.
    That said, I’m running 225/45R17 snow tires on 7.5X17 ET:41 wheels on two E36’s.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Yeah, you probably aren't going to find 16" wheels that fit.
    If you are needing a snow tire, (highly recommended if you are actually going to drive in snow) pretty sure that you really shouldn't go with more than a 225 on a 7.5" wheel. Wider isn't better in a snow tire.
    There are plenty of people that use small wheels (7.5) in winter and change to much bigger wheels and tires in spring..
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by RRSperry View Post
    I would add that OEMs are going larger and larger, which leads tire makers to follow them - and makes smaller sizes harder to come by and reduces options for the smaller sizes they DO make.
    You'll have far better luck over time with 17s than trying to make a 16 work.
    Nov 2013
    VA
    E36
    Never seen a 16" wheel clear the front brakes on an e36 m3. Offset would have to be pretty low..
    Dec 2011
    Montana
    97 M3/4/5 F31 328i Wagon
    Yeah, the 16" stuff is just not a real option. I've seen one or two wheels that fit, and they looked horrible.
    I run the M-Contours 17x7.5 (225/45-17 tires), 17x8.5 (245/40-17) staggered setup for the summer, and a 17x7.5 square setup with 225/45 tires all around for winter.
    Current: E36 BMW M3/4/5, F31 BMW 328i xDrive M Sport
    Past: Mk6 Golf R APR Stage 2, E30 325i/4/5, E36 328iS/2/5
    Aug 2013
    1999 BMW M3 Coupe
    Yeah just run stock tire sizes if you have the OEM size wheels (17x7.5 ET41 front, 17x8.5 ET41 rear). The 225/40-17 and 245/40-17 sizes are still common and relatively inexpensive. If you want to buy aftermarket wheels and go to a square setup instead of staggered, a 17x8.5 or 17x9 with a 40+ offset should fit a 245/40 all around without much fuss.
    Jun 2004
    New Jersey
    E28, 97' M3/4
    Quote Originally Posted by blckstrm View Post
    They exist. Ive had them for the past 7 years. Yes they're ugly but they are my winter set so I really didn't care. Mille Miglia (probably spelled that incorrectly) Spyders. Tire size is 205/55-16
    Thank you very much for all the feedback. You guys are pretty spot on !
    Here are pictures of the owner's manual that was provided by a friend.
    It looks like there is a mistake showing an option for 245/40r17 for both front and back on staggered wheels ??
    The consensus is pretty much 225 in front with 245 in rear on staggered wheels...
    He kept everything and I'm attaching the winter recommendation that came with US cars:
    It does specify a square 215 setup on 7 inch wheels .
    This is my table to summarize all options for both season as I understand it:
    Thanks to does who contributed.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Franky goes View Post
    LOL!!! Need a slightly more clear image.
    FWIW - The 1995 LWT was fit with 235/40-17 tires all around on 7.5 X 17 and 8.5 X 17 ET:41 Style 24s
    …too wide for 7.5” and too narrow for 8.5”, though that was the size of my RA1s back in the day.
    Oct 2003
    Seattle
    99 M3
    LOL!!! I can guaranty that 245/40-17s on 8.5 X 17 ET:ET41 will rub and ride hard on the strut of an 1996+ E36M3
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Braymond141 View Post
    And oddly there are some different 17s listed for the non “M” E36 -
    http://www.realoem.com/bmw/enUS/show...diagId=36_2180
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    Those would be them... Probably onobtainium new or used now...
    Pretty sure you don't want 9" wide snow tire wheels..
    What you want is a 7.5" Et40 5x120 wheel and a 225-45 snow tire.
    If you don't want new wheels and are looing for just tires. the stock 225 front, and 245 rear is acceptable, but....
    My car never sees winter, but has (4) 17x8 Et38 BBS Rg-r's and wears 245-40-17 tires. They don't ever rub. (H&R OE Sport Springs, Koni)
    NoVA
    97 M3
    Mine wears 225/45R17 General Altimax Arctic 12s on 17x7.5 M-Contours for the winter out here in CO/WY. These plus the LSD work great in snow, slush, ice, or warmer, dry end-of-season conditions. There were many options in this size when I went and purchased them last year, but I had a positive experience with the previous iteration and decided to try these out. I highly recommend them.
    '97 M3/2/5 Lux, AW/Modena, ~225k, many mods and lots of grip
    Please lift when giving a point by
    Nov 2013
    VA
    E36
    I've always had good luck with square 225's in the winter. For summer, staggered 225/245 or even square 245's.
  1. Wheel and tire sizes question
    By jkearns13 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-19-2003, 05:01 PM
  2. Tire Size Selection
    By X Brian X in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-19-2003, 09:18 PM
  3. wheel and tire size???
    By e30bimma in forum 1983 - 1991 (E30)
    Last Post: 01-07-2003, 08:53 PM
  4. Contour wheel; max tire size?
    By Edster in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-18-2002, 10:39 AM
  5. If I get 18x18.5 wheels what tire size should I get?
    By BMWDRIVEN in forum 1991 - 1999 (E36)
    Last Post: 11-17-2001, 09:04 PM
