BMW of Bloomfield
Results 1 to 4 of 4
Thread: 1991 325i S50 Swap (Albany NY)
    Nov 2018
    upstate ny
    1991 325i S50 Swapped
    SOLD 1991 325i S50 Swap (Albany NY)
    Up for sale is my Brilliantrot 1991 325i with 1995 M3 engine and transmission. The car has been very heavily modified with the aim of creating an incredible driver’s car which turns heads and can be taken grocery shopping.
    The car was built in March of 1991, making it a last year and last month model. The car was sold in Virginia that July. The vehicle was taken off the road sometime between 2005 and 2006, and was not re-registered until 2013. It spent a just under a year in Minnesota before being brought to New York where it has remained since.
    I purchased the vehicle in January of 2017 and in May of 2017 swapped in an engine and transmission from a 183K mile 1995 M3. The engine had been serviced thoroughly by it’s previous owner including welding of the oil pump nut. The engine was tuned by RK tuning on long island before I purchased it.
    In May of 2018 the vehicle was hit on the right front corner, which pushed the right front wheel into the passenger’s footwell and totaled the car. Luckily the subframe, shock tower, and all other mounting points remained intact. The car was professionally repaired by replacing both front fenders, valence, bumper, and completely respraying the car. At this time all the rust was repaired except for a small hole under the battery.
    As I am moving to California I would rather sell this than go through the expense of making it SMOG legal.
    Modifications:
    Suspension:
    Bilstein Sport dampers with Ireland Engineering progressive race springs
    Z3 steering rack (power steering deleted)
    Increased caster front lower control arm bushings
    Reinforced front subframe
    Wheels are 16” style 5 from E32 which have been filled and redrilled to 4x100 before being refinished. Slight curb rash present.
    Tires are Continental Extremecontact Sport and have less than 5,000 miles
    Custom wheel spacers/center bore adapters
    Brakes:
    Wilwood 4 piston Dynapro calipers in front with EBC Yellowstuff pads / Volkswagen Corrado rotors
    Rear calipers are stock - recently rebuilt
    New rotors and pads all the way around
    New stainless steel lines
    New E32 M5 master cylinder
    325iX brake booster
    New 2002ti remote reservoir
    ABS works
    Engine:
    1995 BMW S50 Engine
    Recently replaced water pump and thermostat
    S50 intake
    Ebay equal length headers
    New Borla Pro XS muffler used as resonator with Vibrant Street Power muffler
    New 318is Radiator
    New Spal 16” pusher fan with low temperature fan switch
    New RevShift 80A polyurethane engine mounts
    New Cone filter
    Fuel pump replaced shortly before purchase
    Oil level sensor gasket leaks
    Driveline:
    1996 325i driveshaft
    New center support bearing with engine swap
    Z3 3.15 Torsen LSD
    Replaced all CV boots within last 10,000 miles
    New Polyurethane differential mount
    New Polyurethane transmission mount
    New Z3 1.8 shifter with all new bushings in last 10K miles
    Interior:
    Incredible black leather sport seats, amazing condition
    New blower motor and climate controls
    8 button clock
    New Renown 280mm steering wheel
    ZHP shift knob
    JVC single din head unit
    Replaced odometer gears
    Center console has been modified for cupholders
    All lights work
    External thermometer replaced
    No lights on dash
    Seat belts have begun to fray
    Carpet has seen better days
    Exterior:
    Resprayed in summer 2018 by Paintworx in Albany NY. 2 stage. Brilliantrot. Window trim removed but all windows remained in.
    New Morimoto HID’s in stock Ellipsoid housings
    Perfect condition fog lights
    Almost every piece of trim has recently been replaced
    IS lip and spoiler
    Antenna deleted
    Sunroof works perfectly
    No leaks
    Tail Light seals replaced
    New Euro Grilles
    All lights work
    Some rock chips in front valence
    Considering all the work that has been put in and the fresh respray I am asking $15,000, but am open to offers.
    https://imgur.com/a/gCqpAOo
    Nov 2017
    San Francisco
    1987 BMW 325is ///MSport
    Beautiful car! Have you had any issues with the fill and drill on the wheels? I'm tossing up whether to do that or go with adapters.
    Jul 2003
    FL
    SO M4
    sweet glws
    Nov 2018
    upstate ny
    Sold
  1. Feeler 1989 325i s50 swap fs
    By 1optimusprime1 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 06-16-2010, 08:58 AM
  2. FS: 90 325i s50 swap
    By B Marques in forum 3 series & Z Series
    Last Post: 12-07-2009, 09:10 PM
  3. FS:Delphin/black 89 325i (S50 swap/5lug) CA SMOG legal!
    By .Tom. in forum 3 series & Z Series
    Last Post: 08-21-2007, 09:44 PM
  4. 1994 325is s50 swap
    By bimmerman1982 in forum Engine Conversions
    Last Post: 01-31-2007, 09:10 AM
  5. F/S: 325i s50 swap
    By randa// in forum BMW Cars For Sale / Wanted
    Last Post: 01-27-2007, 06:53 PM
