Results 1 to 7 of 7
Thread: Passenger side Valve cover not sealing
    May 2013
    Washington PA
    1994 540iA, 2004 Jetta
    Did the valley pan job and timing cover jobs over the summer and now my right Valve cover is leaking with new gasket. I sanded the channel out and even replaced the gasket again and she still drips sometimes under high crank pressure. I even swapped the rear PCV plate with an extra used one I had lying around in case the breather was bad.(Still could be I guess). Engine runes great and theres no symptoms of it failing. No gas or coolant in oil and I even opened the coolant cap and revved the engine up and nothing. Maybe I someone bent the cover when I had it off? I used a mirror all over the dang thing and I dont see it coming from the head.
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    May 2013
    Washington PA
    I think its at the "Half Moons" at the rear. I tried RTV the second time and it didnt work so I sanded it all out. I have another cover to try. Ive been using Victory Renz gaskets
    moroza's Avatar
    BFE
    E34T
    Reinz and RTV at the half-moons should work just fine. What're you using for RTV and what's your technique? Other than assembly errors (related to RTV, or tightening torque and pattern), the only thing that comes to mind is small cracks in the valvecover itself. Maybe try seating the gasket onto the head first, then the cover? RTV should only be necessary on the underside - the half-moons themselves, and at the timing cover seams - and more is not always better.
    May 2013
    Washington PA
    Quote Originally Posted by moroza View Post
    I better youtube some technics for applying it then. Ill report back when or if I get it fixed for any future searchers.
    May 2013
    Washington PA
    I found it the leak and its not the valve cover. It the right timing chain cover I didnt do (Only did the left one). It leaking right onto the AC Unit and exhaust. I was scared to do it over the summer cause you gotta remove the tensionor bolt and it honetly wasnt leaking this bad back then. If I can remove the bolt without jacking the timing it should be an easy peasy job compared to the left side.
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    Did you tighten the nuts from the middle outwards? I think the technique in tightening the valve cover is similar when tightening head bolts, starting from the middle then a cross pattern and in stages, for the tension to start in the middle then move outwards.
  1. Loud tapping at passenger side valve cover
    By FR540I in forum 1996 - 2003 (E39)
    Last Post: 06-21-2012, 04:56 PM
  2. WTB: Passenger side airbag cover
    By audidriver18 in forum BMW Parts Wanted
    Last Post: 03-16-2005, 02:46 PM
  3. Passenger side window will not go down
    By Gigs in forum 1988 - 1994 (E32)
    Last Post: 02-28-2005, 02:51 PM
  4. warped passenger side airbag cover
    By tinman in forum 1996 - 2003 (E39)
    Last Post: 01-23-2004, 03:36 PM
  5. F/S Passenger side airbag cover- Black- 2 dr
    By EndangeredBeatz in forum BMW Parts For Sale
    Last Post: 09-12-2003, 12:46 AM
