Results 1 to 7 of 7
Thread: Turbo M5x Power on Pump Gas
    Jan 2017
    Kitchener, Ontario
    1999 BMW M3 Convertible
    I'm sure this has been answered/explored, but I'm unable to find it. I currently have a turbo'd M52 (stock block, Steedspeed mani, GT35R, S52 cams), and am looking at building a proper engine in the future and just looking for the best combinations/possibilities with the M/S5x family of engines.
    I do not have access to E85 in my neck of the woods, and I don't want to run meth, so here's my question: What power levels are possible on an M5x with any combination of bore/stroke, cams, head work, turbo, etc. but limited to 93 octane fuel and no meth?
    Summer Daily -- '99 E36 M3 'vert 5MT
    Current Project -- '97 E36 328is Coupe 5MT
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I’d stick to around 600 rwhp on just 93 pump. With meth, I would push it to 700 rwhp. For the most power on just 93, be as efficient as possible so you make the power with less boost. Bigger turbo, better cans, better head flow, bigger exhaust, more displacement.
    It’s expensive to fully work a head and buy cams. I have nearly $5k in my CES Extreme Ported head and Schrick cams, much more than it cost to fully build the 3.2L shortblock.
    The tune may be the most important part of keeping the motor together when pushing the limits on pump gas. I would have the most faith on a NickG dyno tune.
    I run meth and recommend it for safety when pushing the limits. I am not tuned for it and have it for octane consistency, cooling and a safety margin. I think I am around 700 rwhp but need to dyno again.
    Apr 2006
    Minnesota eh?
    86 325es
    600 whp has been done countless times on a low compression built motor. I would not be afraid to try for 700-800 with a direct port meth kit with a flow sensor and ecu safeguards
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Ive been meaning to make a thread on whats the best to do to the head. I didn't know CES did headwork.
    Does anyone have an opinion on who does the "best" or most reliable head work?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Jun 2005
    New England
    CES farms the work out to a NASCAR guy. It is pretty extreme. It is also a lot of money to put into a head that could get cracked from detonation or damaged by a mis-shift. But you asked about how to get the most power on pump gas, not about the best bang for the buck.
    May 2003
    Richmond, Virginia
    Lots.
    Quote Originally Posted by 3literheater View Post
    I've seen Headgames work on S54 heads and would imagine they've also done M50/S50 heads. They are the go-to for Supras and other makes for big flow and power.
    915whp '98 M3 Sedan /// 37k Mile '95 M3
    Jul 2005
    California
    Bima
    i feel old looking at this and thinking
    "why the F do you want more then 600hp. Can you even get that to the ground?"
  1. 600whp Pump Gas Turbo Choices
    By cragg56 in forum Forced Induction
    Last Post: 03-21-2013, 04:49 PM
  2. ICS Twin Turbo M Coupe 24 PSI Pump Gas Dyno Graph
    By Handbuilt in forum Forced Induction
    Last Post: 01-21-2012, 12:05 AM
  3. Who has the most power on pump (94 or lower) gas (meth allowed)?
    By 5mall5nail5 in forum Forced Induction
    Last Post: 12-08-2010, 08:55 PM
  4. Pump gas brands differ in power potential?
    By mazur in forum Forced Induction
    Last Post: 01-24-2009, 04:13 PM
  5. Replies: 19
    Last Post: 08-16-2008, 08:27 PM
