Results 1 to 11 of 11
Thread: Is anyone using a 125/80/16 spare?
    Feb 2009
    Charlotte, NC/Denmark
    2K Z3 2.8
    Well, the stock size 125/90/15 tire seems to be extinct. You can go without spare, put on your 17 year old donut and cross your fingers, or buy another (old) one off eBay and THEN cross yoru fingers.
    BMW part # 36116750006 is for a 16" rim and with the Kumho spare tire in size 125/80/16, that lands the dimensions about as close to identical as possible.
    After inspecting my donut. I'm not going to put it back in!
    I'm thinking about pulling the trigger on this setup. Is anyone running it?
    125/90/15
    Diameter: 23.9"
    Width: 4.9"
    Sidewall: 4.9"
    Circumference: 74.9"
    Revs/Mile: 846
    Replace with: 125/80/16
    Diameter: 23.9"
    Width: 4.9"
    Sidewall: 3.9"
    Circum: 75"
    Revs/Mile: 845
    Zed's dead baby. Zed's dead.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Hmm, sounds like a great alternative. ~$90/tire and ~45/wheel plus install.
    A 15" (or 16") wouldn't fit over my front Coupe brakes, so if I ever got a flat in front, I'd have to put a rear wheel on the front and the donut on the rear. But, not sure how I'd accomplish that as I don't carry jack stands in the hatch. Or, is the offset such that the brakes don't run inside the rim?
    Thankfully my AAA membership is up to date.
    Nathan in Denver
    Feb 2009
    2K Z3 2.8
    See .... that's why I'm back and forth on it. I have AAA also, and don't really plan on taking this car further from the house than can be towed.
    That being said ... there is that space underneath where you CAN indeed put a donut, so why not have one.....
    May 2015
    Maryland
    1998 M Roadster
    Wouldn't the Kumho T125/80D15 work on your original rim? It is smaller in diameter at 22.9in but it is a spare for short term use. I have a M so no spare tire problem, all AAA.
    May 2015
    Maryland
    1998 M Roadster
    Jul 2004
    Houston, TX
    36 Cylinders
    On the newer cars they make an alloy 5 spoke 17", 4" wide ET5 for 135/80R17 tires. I wonder if it would fit?
    http://www.realoem.com/bmw/enUS/show...diagId=36_1274
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2009
    2K Z3 2.8
    The spare is already smaller than the full size wheel. I just don't feel very good about putting an even smaller tire on there - especially if it's the rear!
    I put air in my donut and disconnected that "check pressure here" hose which just doesn't seem like it would help the matter.
    At 18 years old - I'm not sure how much faith I have in it though.
    That alloy spare looks cool, but does not appear easy to get a hold of and I wonder if it costs an arm and a leg.
    Sep 2018
    Alexandria, VA
    2000 BMW Z3
    So did you try it? My 15 in spare is questionable and considering the 16 in with Kumho tire myself.
    Steve
    Alexandria, VA
    2000 BMW Z3 Roadster 2.8
    2020 BMW 230ix (Convertible)
    2015 MINI Cooper S (Convertible)
    2015 Jeep Grand Cherokee Limited
    Feb 2009
    2K Z3 2.8
    I haven't done it yet, although I still intend to.
    My Z had a "dubious" stereo install done by a PO and in a moment of weakness I had ordered a giant box of stuff from Crutchfield, so I am forcing myself to finish this before I tackle other areas.
    Jun 2016
    Montreal
    2000 BMW Z3
    Anyone try the 16inch upgrade? Curious if its going to fit in the 15inch carrier.
    Sent from my SM-G950W using Tapatalk
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    I just roll with fix a flat. Its never not worked for me. Unless you really destroy your whole sidewall it will work in most cases. No point in trying to find a wheel that would work when I can buy a 10$ can, and its not like my car has TPMS sensors to ruin so the tire can be plugged if possible
  1. Looking to Buy: 125/80/17 TIRE (for spare)
    By RickySixx6 in forum Wheels and Tires
    Last Post: 11-02-2011, 04:49 PM
  2. Anyone using this "Center Console" (Part #51 16 8 413 622)
    By Estrl M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2011, 02:36 PM
  3. Anyone using a 16-volt battery
    By tsweers89 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-01-2007, 09:37 PM
  4. Anyone uses V-1 in Northern VA/DC area?
    By vroo//M in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2001, 10:35 AM
  5. Anyone uses V-1 in Northern VA/DC area?
    By vroo//M in forum 1991 - 1999 (E36)
