Results 1 to 10 of 10
Thread: BMW 2014 X3 F25 Oil Filter Housing Gasket Replacement(Case Study)
    Oct 2018
    New York
    E53 4.6IS imola red
    How to change an oil filter housing gasket for BMW 2014 X3 F25.
    It is a matter of time before your oil filter housing gasket will start to leak oil and make a mess of things. luckily for you, in this article, I will be explaining how you can change the gasket yourself the right way so that it doesn't create future problems down the line so you can continue ownership of your vehicle.
    But first, here's a list of the tools you will need.
    [su_list icon="icon: car" icon_color="#FE8E48"]
    • Female Torx socket E10 and E12
    • 3/8 and 1/4 ratchet
    • 8MM wrench
    • Oil filter tool
    • 11MM socket
    [/su_list]
    BMW F25 2014 X3 case study.
    If you are reading this article then chances are you opened the hood of your car one day and noticed a massive oil leak concentrated in the front of the engine.
    Trust me when I say you are definitely not the first person in this world to suffer from the notorious oil leaks from your BMW car.
    Valve cover gaskets, oil pan gaskets, rear main seals and oil filter housing gaskets are the major areas in where you will experience oil leaks on your engine.
    The engine in this X3 is the BMW N55 engine and this article can be also used to help you if you have this engine installed in other applications so it won't be just limited to this vehicle.
    Today I will be writing an in-depth guide on how you can change your own oil filter housing gasket and save on costly repairs at your local stealership. so continue reading and follow along!
    What is an oil filter housing?
    To start things off with everyone, the oil filter housing is not the first thing involved in the lubrication system of an engine but it is in fact within the same working system.
    All engines have moving and sliding parts made of either steel, iron or other metals and create a lot of friction. to prevent any damage to any of the engine internal parts and oil pump is created and forces oil throughout the engine lubricating all moving parts.
    The moving parts must be well lubricated to prevent wear and prevent as much friction as possible to maintain the longevity of the engine.
    An oil pump which is usually bolted at the bottom of the engine and is driven by the engine forces oil up into an oil filter then the oil passes through the rest of the block and cylinder head to lubricate the whole engine.
    Oil is forced up to the oil filter housing and in essence, cleaning the oil that comes from the oil pan and then travels to the other oil galleries and then returns back to the oil pan by special bores in the engine and drains back down.
    Oil temperature is a big factor in any engine and especially for high-performance engines like in BMW cars. a larger oil pan helps control overall temperatures and in some cases like the turbo applications then a separate oil cooler is installed in the vehicle.
    Another cool fact is that Coolant flows through the oil filter housing to help warm the oil when the engine is cold and helps cool it down when the engine is hot.
    Now for the meat and potatoes of this article. down below is where I will show you step by step how to replace yours if your gasket goes bad and oil starts to leak out and create a mess as it does in most cars.
    How to change an oil filter housing.
    Now if you are not familiar with any of the terms or any technical stuff regarding your car then don't sweat it and never worry too much because I am here to explain it to you the best I can in order to help you.
    It can be a daunting task if you are not experienced with anything that has to do with the mechanics behind how your car works and such.
    As you follow along to my tutorials I will do my best ability try to explain how you can execute the job correctly without any mistakes and mishaps.
    The very first step to take here and to prevent any issues along the way is to always make sure you have the correct parts available.
    There is nothing more that sucks then taking everything apart only to realize that you ordered the wrong part or missing other parts to complete the job.
    With that said, let's dive into replacing your gasket with my easy to follow instructions that will help you save money and gain experience at the same time.
    The first step to take is to lay out all your tools on the table or if you have a toolbox have them ready to start using them. now pop the hood and remove the engine cover which is easy. just grab it in the front and pull it up slowly. it has rubber grommets.
    Then what you want to start doing is removing some of the plastic pieces on top of the engine such as the air duct and engine air filter box. you will have to pull upward hard to remove the box from rubber grommets they sit on.
    Then what you want to do next after you have removed the air duct you want to work your way up to the airbox so loosen the 6MM hose clamp as I show you in the picture below and remove the airbox completely.
    Now with the airbox and air duct removed your engine bay should look like this in the picture below.
    Towards the fuel rail and where you see a wire loom heading from the front of the engine heading to the back, you want to just lift it up and move it out of the way to get to the (7 to 8) 11MM nuts that bolt the intake manifold to the cylinder head.
    Now that you completed all the preliminary steps in order to do this job the next thing to do is loosen the oil filter so that the oil sitting in the housing can make its way down to the oil pan.
    If you don't do this then there will be way more oil and a bigger mess up there when you remove the oil filter housing. check out the picture below so you know what I mean.
    The next step you want to do is to loosen all the 11MM nuts that bolt the intake manifold down to the cylinder head. this is a method I do in order to create space because there is an oil filter housing bolt that sits behind the intake manifold.
    Some people remove the whole intake manifold completely but trust me you don't have to actually remove it just unbolt it and pull it up just enough to clear the one bolt hidden behind it as I will show you in the pics below so continue reading.
    After you have removed all the intake manifold nuts and one bolt towards the front of the engine then you have to just shift it upward and pull it up so that you have enough space for the Torx E10 bolt.
    Move all the wire looms and everything that might get in your way so you can have the most space possible in order to do this job without issues.
    Now to remove the first part of the oil filter housing. in the picture below I show you that you have to remove three Torx E12 bolts in order to remove the oil cooler.
    You can use a regular 3/8 ratchet of your choice but for me, in the picture, I use a snap-on ratchet with a small adaptor and have always used this setup.
    There will be three bolts in total here for the oil cooler in the picture below. for this part, you want to place a towel or a shop rag under or covering the drive belt.
    You want to cover your drive belt from oil because the oil deteriorates the belt and rubber material so you want to try to keep the belt clean as possible.
    After you covered your belt and removed your intake manifold bolts the next thing you want to do now is to remove the three E12 Torx bolts that bolt the oil cooler to the oil filter housing. keep the coolant cap on to keep most of the coolant from spilling out.
    After you have removed the three bolts from the oil cooler in the picture above you will have a lot of oil and some coolant leak out and make a mess so make sure you place some shop rags underneath to catch most of it.
    An important habit in any technicians work ethic is to always be clean in all he or she does so try to keep it clean guys in everything you do.
    Now once you have removed the oil cooler from the oil filter housing then what you want to do is to move it to the side as I show you in the picture below and also pass a rag on it to clean it up a bit.
    Then after that, you will want to use a right angle pick or a pick of your choice to remove the actual gasket from the front side of the oil filter housing. there will be a total of two gaskets in the housing.
    Now you have already removed the front oil cooler and the gasket for the front side of the oil filter housing and are halfway through this whole job which is amazing! keep it up.
    Now the next step in order to complete this task is to actually remove the oil filter housing in itself. now we have to tackle the three bolts holding it to the cylinder head.
    In the picture below there will be a Torx E10 bolt that you have to remove in order to remove the housing from the cylinder head but sometimes if it is seized or has not been removed in a long time then it can become difficult to remove.
    Sometimes what I do is I light up the torch and pass the flame on the bolt just a few times to heat it up and expand it in order to loosen it up. do not keep the flame on it for too long so you won't warp the housing being that it is aluminum.
    Now you have to loosen the E10 bolt so you can remove the housing but for me, I use an 8MM wrench open end to remove the bolt because it was a fairly new car with low miles and it was not seized.
    After you have removed this one bolt from the housing, you can actually move onto the next two bolts on the housing. remember when I told you we have to unbolt the intake manifold in order to get to one E10 bolt?.
    In the picture below you will notice the one hidden bolt behind the intake manifold that we also must remove in order to remove the whole oil filter housing from the cylinder head.
    This is why we have to unbolt the intake manifold bolts in order to release the housing from the head. just pull up the manifold just enough to clear your tools.
    In my case, I used a 1/4 inch ratchet with an extension and a swivel E10 socket at the end of it which makes the job a whole lot easier.
    Now that you have removed the other housing bolt with the open end wrench and now you have removed this bolt the next thing to do is to remove the remaining bolt which you can't miss because it is at the top.
    The picture below will show you where the bolt is as a guide if you miss it or do not understand.
    This is the last bolt to be removed in order to finish the job correctly but sometimes you can run into issues such as bolts being seized from not being removed or lubricated properly with anti-seize so it is a good habit to start putting anti-seize on all your bolts.
    Sometimes the E10 Torx bolt at the bottom of the housing does not want to move so I end up torching it and if that does not move it and the head ends up being stripped, I then end up taking a chisel and hammer and chipping it counter-clockwise at the head to try to release it.
    I don't recommend this tactic for the first attempt but when working in the field for such a long time you will be bound to run into problems such as the one I mentioned and that is when experience comes into play. so hopefully it doesn't happen to you in this case.
    Now that you have unbolted all of the oil filter housing bolts it is time to actually remove it from the cylinder head. it will make a mess so be ready with rags to catch most of the oil and coolant.
    If you want you can remove the upper radiator hose before you unfasten the whole housing so you can clean it somewhere outside of the engine bay but for speed it is ok to just move it to the side and then clean it all up after you install the new gasket.
    Now just use a small right angle pick or whatever you have that will easily remove the gasket from the housing.
    If you can run over to your local auto parts store and pick up at least three cans of brake cleaner and use it to clean all the excess oil that leaked out from the housing creating the big mess.
    Sometimes you can clean as you go but you can also just replace the gasket and then clean up after you install the new gasket so whatever you decide to do just try to stay clean as possible.
    Here at the shop what I usually do is a create a mixture of 20% detergent of your choice, 30% solvent, and the rest water in a small spray bottle and spray away. let it soak and if you have a small brush laying around in the garage then use that to clean it up a bit.
    After you had let the soapy spray sit and pass the brush over it to break down the oil deposit and gunk then simply blast it away with the brake cleaner and it will do justice.
    Now simply wipe or blast the cylinder head clean and install the new gasket on the actual housing then bolt the housing to the cylinder head and tighten the bolts down to the head. please do not over tightened the bolts because you can warp the housing.
    Bolt the three housing bolts down and then install the new gasket in the front side of the housing and bolt those three bolts down of the oil cooler evenly.
    After you have installed the new gaskets and bolted the main oil filter housing and the oil cooler in the front side of the housing then simply bring back down the intake manifold and fasten all those 11MM nuts down.
    The engine air filter box will be next. then after that the air duct but to keep things simple, just install everything in reverse order and at the same time clean up all of the oil mess.
    Keep in mind all of that oil you just spray and cleaned will travel to the bottom of the engine so you may have to jack up the car and remove the plastic cover and clean that up also.
    And there you go! now you have successfully replaced your oil filter housing gasket on your N55 engine with ease!
    If you enjoy this type of content please share on your social media platforms and forums. any type of exposure to my content will be greatly appreciated. I enjoy teaching and helping others with their problems related to German cars.
    If you haven’t yet please subscribe to my newsletter here to stay up to date on a weekly post on subjects like diagnosing, repair, industry news and much much more.
    Thank you for reading and happy motoring!
    Dec 2018
    Edmonton, Alberta, Canada
    BMW E70 4.8
    Great guide!
    Oct 2018
    New York
    E53 4.6IS imola red
    Thank you brother!
    If you have any suggestions on a future post or anything you guys would like for me to review feel free to reach out and inquire.
    May 2015
    Burnaby BC
    2004 530I
    Thanks to the author as this was very helpful post.
    Today was the first day of school in North America, but it's only 1h orientation, so I knew I had to take off from work and I wanted to make the afternoon useful. We went to the local store to get the two replacement gaskets.
    I will share some additional info that might help you prepare for the job:
    1. I can confirm that unbolting the intake is enough, that's a great relief.
    2. The best tool for the hidden bolt is 8mm ratcheting wrench like this one I got from Sears:
    3. The etorx bolts gets really banged up, so it's not a bad idea to get the whole set from FCPEuro - both gaskets, and fresh bolts.
    4. My socket wrench was unable to fit to remove the green arrow bolt, so I had to remove the coolant hose - red arrow. Those are 10 mm bolts. I was planning to flush the coolant one of these days, so stuck the garden hose while I had my dinner. Tomorrow I will drain it again and top-up with fresh blue coolant. I am suspicious about this green stuff.
    And do not forget the electrical cable - orange arrow has to go over on top before you mount the housing otherwise you'll have to take it again like I did.
    5. Make sure you carefully clean the housing and check for corrosion. I discovered this notch on my housing, but I have to go to work tomorrow and I installed everything back, so I will monitor it for leaks until I get new housing.
    Good luck
    Feb 2020
    Cincinnati, Ohio
    2014 BMW X3 F25
    Thanks for such a detailed explanation! I have a 2014 X3 F25 with the N20 motor. Would the process to replace the 2 oil filter housing gasket be exactly the same? If not how would it differ? Good to know the only reason to loosen the manifold it to get to one bolt on the oil filter housing.
    Also, do you have to replace the 4 gaskets on the intake manifold as well? (My dealer gave me a $580.00 estimate and said they also have to replace those 4 intake manifold gaskets because once they loosen the manifold they cannot be reused).
    Thanks again.
    Feb 2020
    Cincinnati, Ohio
    2014 BMW X3 F25
    Update to my last post(above): I found a reputable indy bmw shop who'll replace the 2 Oil filter housing gaskets out the door for $428.
    Also, another bmw dealer in town quoted $510 out the door. (Both said they won't have to replace the 4 intake manifold gaskets). More $$ than I hoped for but better than the $580 the other bmw dealer quoted.
    Recommendations? Should I go with the indy shop to save $82? It'll probably be hard to find a lower price than $428.
    Mar 2015
    Atlanta
    '01 M3 LSB, '13 X3 35i
    You are my hero for creating this tutorial
    May 2009
    Denver, CO
    2001 BMW M5
    I was told by the dealer that when pulling the intake manifold up it's possible for the intake manifold gasket(s) to 'roll'. I've pulled mine up an inch or so (max it will come up without removing the intake piping, ECU wiring, etc) and it's not possible to see the gaskets. Anyone have any issue with this after pulling the intake manifold up?
    Jan 2016
    Ca
    2001 525it
    Also if people would just open there hood get a flash light and just around regularly, they will see if the gasket is leaking
    Mar 2021
    Lebanon, NJ
    2004 M3 2006 X5 2015 X3
    How similar is this procedure to my 2015 x3 xDrive 2.8i (N20)? Wife pulled into the garage last week, oil dripping off the lower pans. Traced it to the oil filter housing gasket (to engine block). Ordered the gasket kit, plan to start disassembly this weekend.
  1. N54 Oil Filter Housing gasket replacement DIY
    By mystreba in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-18-2015, 11:42 PM
  2. 2004 BMW Z4 2.5i E85 Manual - Oil Filter Housing Gasket Replacement
    By CyberDoom in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 05-13-2015, 01:49 PM
  3. e60 Oil Cooler Gasket and Oil Filter Housing Gasket Replacement
    By thewash149 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-24-2013, 11:44 AM
  4. oil filter housing gasket replacement, leaks worse..
    By KwReis in forum 1991 - 1999 (E36)
    Last Post: 02-18-2012, 07:00 PM
  5. Planning an oil filter housing gasket replacement
    By tommyd123 in forum Great Plains & Rocky Mountains - US
    Last Post: 02-22-2010, 06:28 PM
