Car is a 04 X5 (e53). I used NCSExpert to get the info from the GM3 module. Used NCS Dummy to translate it. Everything related to auto door locks is set to Not Active already. There are separate entries for Key1 Key2 Key3 Key4. I have Key1 and I just added a new key (Key7). I would understand if autolock happened with Key7 because it's not entered into the code but it's happening with Key1. I've gone through the entire trace file and everything related to door locks and autolock is set to the correct state.
At this point I haven't made any changes to the code because I can't see anything that needs changing
Tried this?
VERRIEGELN_AUT_AB_X_KMH : automatic central locking afterX KMH VERRIEGELN_AUT_NACH_2_MIN : automatic central locking isre-locked after 2 MIN if you dont open a door VERRIEGELUNGSSCHWELLE : locking Device-swells (threshold) (speed of X above) VERRIEGELN_XKM/H_SENDER_1 VERRIEGELN_XKM/H_SENDER_2 VERRIEGELN_XKM/H_SENDER_3 VERRIEGELN_XKM/H_SENDER_4 (these all have to be aktiv for the auto central locking to work on all keys)
I remember it not working at first for me on a friends e53 until it went to sleep after the 16min of whatever time it takes and then it started working...
Sent from my SM-N960U using Tapatalk
It already works. I want to turn it off. Everything related to auto lock is set to nicht active including all the entries you listed. I must be missing something because it should not be working .
I got it fixed. Not sure exactly why but I created a trace file that contains a lot more items to manipulate than it's supposed to and the ones I wanted to change were already set to the correct parameter .
Started from scratch and got the correct TRC file. Turned off auto door locks and it works great
well ty about this thread now i know my GM3 unit is duff. i have 2 units, 1 says boot n doors opened and the other says boot closed and doors opened. Wondered by car would not lock during drive. o w i know it is the GM3 unit that has failed.
