Results 1 to 4 of 4
Thread: E46 320D Wont Warm Up (prob not thermostat)
    Nov 2018
    Adenau, Nurburgring
    E36 M3 & E46 320D
    Hi All,
    New user here but got a E36 M3 and E46 320D daily. Just picked up the 46 and the car won't warm up at all, on the magic computer will barely get above 65 degrees. However all rad hoses are warm / hot so I suspect the thermostat is OK as it's not got the classic signs of one cold and one warm hose.
    The other red herring is that the coolant light comes on after a few mins of running but I have a good coolant level. I've tried bleeding it but doesn't seem to have made a difference. I've either done it wrong or the fact that the engine won't warm up to anywhere near the 88 degrees recommended is probably something to do with it.
    Any advise?
    Thanks,
    James
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The thermostat is the likely cause of your problem. It’s the only cooling system component that is designed to restrict coolant flow to get the engine up to temperature. What brand is the thermostat? Gasoline engines use a Whaler thermostat so I’m thinking your’s should be a Whaler also.
    The coolant level light is activated when the float in the expansion tank surrounds the reed switch in the bottom of the expansion tank. The switch could be faulty. If your car’s cooling system is similar to that if the gasoline engine cars the switch is very easy to change as it doesn’t require that you drain any coolant. Go to www.realoem.com and enter the last 7 characters of the car’s vehicle identification number. Hit enter and bookmark the page. Scroll down to the radiator section for a breakdown diagram.
    Nov 2018
    Adenau, Nurburgring
    E36 M3 & E46 320D
    Thanks. I’ve picked up a thermostat and will have a crack at it today.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What brand is the new thermostat?
  1. E46 320d cranks only when warm. Temp guage goes up!
    By wezdidit in forum 1999 - 2006 (E46)
    Last Post: 03-30-2015, 06:49 PM
  2. E46 320d consumption gauge not working
    By Lionel320d in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-11-2014, 01:50 PM
  3. bmw e46 320d does not start
    By donaat in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-26-2012, 03:31 PM
  4. E46 320d Car Not Starting/Cranking code 4A42
    By Addaz786 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-29-2012, 01:28 PM
  5. Service timer NOT resetting (2003 E46 320d)
    By poolius in forum 1999 - 2006 (E46)
    Last Post: 04-26-2008, 01:37 PM
