Results 1 to 10 of 10
Thread: Headlight Question.
    Nov 2017
    calgary, canada
    2014 328i xdrive
    Headlight Question.
    What is the function on the inner lamp of these headlamps.
    I never see it come on. High beams seem to be stage two of the outer lamp.
    Or is there something wrong with my bi-xenon headlamps?
    Aug 2012
    Evansville, IN
    2006 BMW 530xi
    Bi Xenon means xenon + halogen.
    Xenons are your high and low beams.
    Halogen are for cornering assist, flash to pass and reversing.
    Nov 2017
    calgary, canada
    2014 328i xdrive
    Thanks,. So the inside lamps are halogens?
    Mar 2011
    PNW
    LS E46
    They're cornering lights. They come on with the directionals if you have your headlight switch in the automatic position (all the way left). They started with this nonsense in the E90.
    Mar 2011
    PNW
    LS E46
    I was just looking it up and it appears they switched to the fog-lights in the F30. Nevermind.
    Nov 2018
    parrish, fl
    650i, E350
    I posted on the lighting section a question concerning my lights. I thought the angel eye had slipped down on the high beam light, but actually it is just the chrom trim ring that has slipped.
    Is it possible to correct this without removing the entire headlight assy?
    Also, does anyone know if I can replace the yellow color eyes, with the LED lights that are available on the web?
    My car is an 08, 650i, e64.
    Nov 2017
    calgary, canada
    2014 328i xdrive
    Not sure i get that.
    My fog lights are down much lower to the ground. What do the inside lamps have to do with the fog lights.? Thanks.
    Mar 2011
    PNW
    LS E46
    Nov 2017
    calgary, canada
    2014 328i xdrive
    Well, well. Who would have thought? That is pretty interesting.
    So if the fog lights have that function, what's the point on the inner light?
    Or maybe it's just a reflector .
    Anyway thanks for that.
    Nov 2018
    San Jose CA
    2004 BMW 330CI
    I'm planning to convert the factory headlights with projector of my 2004 330Ci convertible to HID system. I would like to add halos as well and I was asked of the measurements the halos that I need. Does anyone know what halos do I need. The measurement that are listed are 60mm to 155mm (Profile Pivot Ring w/Driver (Switchboard). thank you in advance
    Low beam not working, but high beams are okay on my 2004 330ci convertible. I replaced one of the bub and I saw a little spark as soon I plugged the connection. Turned the low beams on and still didn't work. any idea what's wrong?
  1. Nighttime headlights question
    By Julian in forum 1991 - 1999 (E36)
    Last Post: 05-14-2003, 12:51 AM
  2. E36 HELLA headlights question
    By mcher231 in forum 1991 - 1999 (E36)
    Last Post: 01-18-2003, 09:32 PM
  3. Silverstar headlight questions and fog light questions
    By AgileM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-24-2002, 11:10 PM
  4. Can anybody help me?? headlight question???
    By FCSmthree in forum 1992 - 1999 M3 (E36)
    Last Post: 09-22-2001, 04:23 PM
  5. Serious Headlight question for E36....
    By Bernanke in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-12-2001, 07:54 PM
